Results 1 to 10 of 26
Thread: There’s water in the passenger foot well
    StatsVehicle Info
    Exclamation There’s water in the passenger foot well
    Hope with all this wet stuff falling you have checked your drain holes.
    The one in front of the pollen filter for the new guys, worth a look see hth …..
    Regular Member sristeven1's Avatar
    wirral
    StatsVehicle Info
    mine ok i no this after my car flooded last month lol
    Regular Member old cruiser's Avatar
    slough
    StatsVehicle Info
    Quote Originally Posted by Tadpole View Post
    Funny you should mention this as last sunday I was out checking those, one by the pollen filter was clear but the other one (drivers side) seemed a bit suspect and as accessibility is a problem on this one without removing the scuttle panel, I ended up using a coat hanger thru' the scuttle holes and attempted to clear it that way, have to say water doesn't flow as well out of that one as it does on the pollen filter side, do you find that?
    Cheers Pete
    StatsVehicle Info
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    Best have a check of that one in the morning Pete probably nothing to harm that end I hope ......
    slough
    StatsVehicle Info
    Let me know how you get on.
    Cheers Pete
    StatsVehicle Info
    Had a look see but without removing the trim above the wiper mechanism I can’t see a drain at that end Pete.
    Anyone know if there is a drain to the off/drivers side such as the one near the Pollen Filter …………..
    vectra - c nutters crew
    42 Post(s)
    StatsVehicle Info
    42 Post(s)
    i cant see a drain hole on drivers side terry but cleaned the other side few leaves/dirt ok now
    StatsVehicle Info
    Quote Originally Posted by happypostie View Post
    Best be safe Baz don't want to hear more sad tales of things not working .....
    slough
    StatsVehicle Info
    It's defo there guys on the drivers side, have to say it is a bit difficult to see, and is different in shape to the other side, if you have a look down to the left side of the brake fluid reservoir and the strut turret you'll see where the end of it is and therefore judge where it is in the scuttle area, in fact if you pour some water down into the scuttle area on that side you should see more easily where it is as the water flows out, hope that helps.
    Cheers Pete
    StatsVehicle Info
    Cheers Pete
    See I never thought of that Pete I'll give it a go & get back to you. I must say it would require the removal of the wiper linkage to access it if you had a problem, not the best of designs ........
  1. Passenger Foot Well
    By connor748 in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2013, 19:47
  2. water in passenger foot well
    By crayon in forum Bodywork & Interior
    Last Post: 28th January 2011, 13:31
  3. water in passenger foot well
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2010, 16:39
  4. Vec 3.2...water on passenger side foot thing...
    By vec3.2 in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2009, 09:16
