Thread: how easy is it to change gear box oil on y30dt???
    Regular Member signum03's Avatar
    worthing
    confused how easy is it to change gear box oil on y30dt???
    as above has anyone done this????
    Why would you need to do this?
    I drive 40K miles a year and have never had this done on any car, even up to 6 years old
    The only time the gearbox oil has been drained is when the engine has been removed for inspection
    There isnt a level check plug in the side of the F40 box according to the haynes book and if for any reason you think the level is low the box should be drained and refilled with the correct amount oil.The original specification was for 3.2 litres to be put in but this was changed to 2.4 litres owing to problems with changing gear under certain conditions. To get at the filler plug on the F40 box on my 1.9 I had to remove the battery and the battery box as well and I imagine you will have to do the same on your V6. The filler plug is on the top of the box and if my memory serves me ok it takes an 8 mm allen key to remove it .
    No chance of such easy access in the 3.0 V6 CDTI !
    Equally, different geabox between the 1.9/3.0 CDTI manual and auto
    Regular Member m3ath3ad's Avatar
    Aug 2007
    Minehead
    i had to put new gear box oil in mine, you have to take the battery out and the tray to and you will see the plug, remember to get a pipe and funel to
    worthing
    how often to vx reccommend changing the oil then? there is no probs at all with the box but its at 104,000 , and there is no history having the gear box oil changed? is it a easy or nightmare job??
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Is it possible to cheack the gear box oil level in a 3.0 CDTI Auto ?
    I've never seen gearbox oil changes mentioned in a service book for either the Vectra B or Vectra C
    Equally, you can't inspect it either
    The oil should easily last 10 years, irrespective of mileage
  1. Y30DT Cambelt / Water pump change
    By dshelton999 in forum Engine & Drivetrain
    Last Post: 23rd February 2013, 23:13
  2. Y30DT 3.0 V6 CDTI cambelt change
    By m8internet in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2010, 19:45
  3. Is there an easy way to change the glowplugs??
    By bennettboy in forum Engine & Drivetrain
    Last Post: 13th October 2008, 14:20
correct gearbox oil for 2008 vectrs 3.0 v6 cdti
