Thread: Steering Angle Sensor
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Default Steering Angle Sensor
    My ESP light has been coming on now and then, VX dealer have had it on the diagnostics and come up with a fault with the Steering Angle Sensor.
    Could anyone point me in the direction as to where to find this part? and what sort of money a replacement is?
    Vectra 2003 3.0 CDTI Auto
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    depending on which spec car you have it'll be part of the CIM unit, or on higher spec card with IDS+ its part of the steering rack itself.
    Sounds very similar to what happened to mine
    The indicators would not cancel, at one stage I had BOTH on, the ABS, and TC light
    Replaced under warranty, but the invoice was 200; 150 in parts and 1 hours labour
    I also had to take both keys and passcard
    Mar 2007
    Stockton on Tees
    Where is the CIM located and what would be involved in removing it?
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    Its around the steering column, best tool for removal is hammer and chisel
    Mar 2007
    Stockton on Tees
    Is it a case of removing the steering column cowlings?
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    Column Integration Module (CIM-Module), Replace
    Note: When replacing the control unit, before removing the control unit carry out a "Reset" with TECH 2.
    Remove
    Important: Wheels must be located in the straight-ahead position
    1. Detach steering wheel
    2. Detach steering column panelling
    3. Detach steering column electronics module
    Note: Steering wheel lock must not be engaged, ignition key to position "I"
    Note: Mark the installation position e.g. using a felt pen, so that the steering column electronics module has the same installation position after reinstallation.
    Note: After removing, the shaft of the steering column electronics module must not be rotated.
    • Release nut (1) for twist protector
    4. Detach steering column electronics module
    • Release bolt (1)
    5. Detach steering column electronics module
    • Release wiring harness plug (1)
    • Disconnect wiring harness plug
    6. Detach steering column module
    • Release clip (1)
    • Remove steering column module
  1. Steering angle sensor
    By RichM in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2012, 20:22
  2. Steering angle sensor
    By Gregiboy in forum Suspension, Wheels & Brakes
    Last Post: 1st April 2012, 14:11
  3. Steering angle sensor
    By 1979john in forum Vectra C / Signum Troubleshooting
    Last Post: 16th August 2011, 20:24
  4. steering angle sensor?
    By robwilson69 in forum Suspension, Wheels & Brakes
    Last Post: 23rd December 2009, 12:40
  5. Steering Angle Sensor
    By chanito in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2007, 18:12
vectra c steering angle sensor location
vauxhall vectra c 2004 1.8 steering angle sensor
vectra c steering rack angle sensor
signum power steering angle sensorvectra zc recalibrate steering sensorfitting vectra c steering angle sensorVauxhall steering angle sensor how to replacevectra 3.0 cdti steering anglevauxhall vectra c steering angle sensorvectra c steering angle sensor calibrationsignum steering angle sensorangle sensor vectra copel vectra c steering angle sensor2003 vectra 3.0 cdti steering angel sensorvectra c 3.2 v6 steering position sensorsteering wheel electronics column integrated module vectra chas a vectra 1.8 got a steering angle sensorsignum power steering rack angle sensorwhere about is the angle sensor on vauxhall vectra 2008where find opel c steering angle sensorsteering angle sensor vauxhall vectraкалибриране steering angle sensor on vectra cvectra c steering angle sensor located on steering column vectra c steering angle sensor error winter timelocation of steering angle sensor on vectra c
