Thread: Flat spot!
    Oct 2007
    Gloucester
    Default Flat spot!
    Hi all,
    I have the fabled 1.9CDTi 150 and have found that when under hard acceleration, the car seems to bog down and "stall" at about 2000rpm and occasionally again at 2600rpm. It's like the engine has taken a breath or that the turbo is clearing it's throat before spinning up again and going strongly.
    Any ideas what might be causing this?
    Oh, and the EGR valve was replaced about 8 months ago so I sincerely hope it's not that!
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Have you cleaned out your airfilter and done air box mod?
    Oct 2007
    Gloucester
    Quote Originally Posted by steve View Post
    Have you cleaned out your airfilter and done are box mod?
    Short answer - no. But I will do asap.
    Any other possible causes?
    Nov 2007
    Could it not just be turbo lag?
    Oct 2007
    Gloucester
    No, it happens when the turbo is spooled up and pushing hard. It's as though there is a distinct plateau in the torque curve before it goes up again.
  1. Flat spot :(
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 13th August 2012, 19:06
  2. Flat spot
    By marc vectra sri in forum The 'Off Topic' room
    Last Post: 12th August 2012, 19:38
  3. flat spot but different
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 28th July 2012, 11:40
  4. possible flat spot?
    By andreitone in forum Vectra C / Signum Troubleshooting
    Last Post: 7th August 2009, 15:04
  5. flat spot
    By surreyl31 in forum Petrol Engine related
    Last Post: 16th July 2007, 18:41
