Results 1 to 3 of 3
Thread: Throttle Issues
    Regular Member Ean's Avatar
    Suffolk
    confused Throttle Issues
    Hi All,
    We have a 2004 corsa c. 1800 (Which the missus' drives)
    We have had an on going issue with the throttle, i.e. car jerks, or jus takes and AGE to pick up and respond!
    VX has said it 'could' be either, throttle pedal or ECU issues. They cant say which one will cure the issues.
    Has anyone else had an issue like this? What are peoples thoughts?
    Ta muchly as always!
    Ian.
    (Sorry admin if this is in the wrong place)
    Regular Member gibbon7000's Avatar
    lincs
    Yep. I had excatly the same on my siggy a few months back. To start with I thought it was the turbo, then vauxhall had it for 11 days in total but couldn't find the problem. Took it to a independant vx specialist and they found the problem within 40 mins. basically the ecu would of been around the £700 mark to change and a replacement pedal was £35 from the scrappy so i went with the latter and bingo, it was the pedal. You can get your ecu checked tho. HTH
    Glasgow
    The throttle pedal should be an easy one to diagnose, the fault code will be something along the lines of open circuit at throttle position sender on the fault memory. Fail on that put a new one on to see if it solves the problem if not put it back in the parts department.
    I think there at it most of the time.
  1. Tickover Issues After Cleaning Throttle Body
    By Telboy in forum Engine & Drivetrain
    Last Post: 27th November 2012, 22:58
  2. Where is the Throttle body on 2.2 dti?
    By congaman in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 14:29
  3. Throttle...
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 27th July 2010, 22:50
  4. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
  5. Throttle body
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2009, 20:27
