Results 1 to 10 of 24
Thread: Clay please!
    Birmingham
    Default Clay please!
    Guy's,
    I've finally decided that both my Vec-B and my dad's Vec-C need claying and im going to actually do them sometime soon! I HOPE!
    Can you's lot recommend me some clay and where to get it from?
    So far I have see the Halfrauds jobbie for £19.99, which is the mit, lube and the clay bar.....but the reviews say it expensive....so the floor is your's guy's!
    Im off to put the little one to sleep now so will pick this up in the morning!
    Thanks in advance.
    G.
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Lump's Avatar
    coventry
    Birmingham
    Nice one mate....but what spray do I buy and DO I NEED ONE? Is that the lube, etc?
    Bye bye Vec B
    - Hello Siggy!
    Surrey
    You can use watered down shampoo.
    I would buy a 1 gallon of Meg last touch so you can use that. You then should use the last touch after every wash.
    Quote Originally Posted by Vaux-Man-G View Post
    ...mit lube...
    Makes it sound like a German porn film...
    As for the fluid, speed detailer is the usual one mate, but if you're stuck then water will work (a had to do this before when I ran out half ay through...)
    Surrey
    Cheaper to buy Megs last touch in bulk. Usually £18.99 for 1 gallon with a dilute raio of 1:1 so 2 gallons. Speed detailer is around £8.99 for 24oz. When the mrs has finished with the glass cleaner sprayer give it a clean and use that.
    Birmingham
    If water is as good as anything, water it is!
    Also, what do I need to do, is it just a case of rub it over the paintwork? Do I need to do anything after this or is the clay it?
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    [quote=Penfold101;1022834]Makes it sound like a German porn film...
    [quote]
    Sorry about all the Q's, but I am a clay "virgin"!
    Bye bye Vec B
    - Hello Siggy!
    Spray the paint, rub the clay over - it should glide smoothly over it. If you feel any resistance then you need more lubricant as you'll be damaging the paintwork itself...
    After a few rubs over an area, slide your hand over it and and compare it to an area you haven't done, and you should be able to feel the difference...
    I'd get some proper lubricant if you can, I only used water as a last resort and don't know if actually did any damage to the paint or not.......
    Regular Member Swaite53's Avatar
    South Wales
    I buy the Meguiars Clay kit from a company called Polished Bliss:
    http://www.polishedbliss.co.uk/acata...kit-clean.html
    I used it for the first time 2 years ago. Nothing to be scared of, just use plenty of lubricant and don't rub to hard. The paint felt like glass after I'd used it. I honestly think it felt better than new. Well worth the effort.
  1. To clay or not to clay?
    By rob warrington in forum Detailing and Car Care Discussion
    Last Post: 28th December 2011, 19:13
  2. Gonna take you to a clay bar, clay bar CLAY BAR!!!
    By peppered in forum Detailing and Car Care Discussion
    Last Post: 7th September 2009, 21:11
  3. Clay - WOW!!
    By davree in forum Detailing and Car Care Discussion
    Last Post: 16th March 2009, 14:24
  4. Clay Day
    By T4M in forum Quick Photo Album
    Last Post: 6th May 2008, 19:15
  5. What Clay??
    By DeathStar in forum Detailing and Car Care Discussion
    Last Post: 27th January 2008, 23:58
