Results 1 to 10 of 15
Thread: Air Con not working
    Full Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Unhappy Air Con not working
    Hi guys,
    Having some problems with the air con in my 07 vectra sri, it makes a hissing noise when i turn the air con on and the noise stays on, also the air con is not blowing out cold air as cold as it use to or not cold at all.
    Thought about a regas but ask here just in case it is a known fault you guys know about.
    Cheers.
    Surrey
    Get an AC guy to re-gas it first but make sure he puts dye in.
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Quote Originally Posted by steve1975l View Post
    Thanks, I try that first
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I get mine done at Kwik Fit £45. They pressure test it first and if its leaking they dont charge. Please note this is the only thing I would recommend Kwik tw*ts for!
    Surrey
    I would take it striaght to someone who can repair it not just top it up.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Oh I forgot to say if any of the pipes are gone they are not cheap, even the washers are about £10 each
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Eek
    Thanks for help guys, I'll take it down to Kwik fit tomorrow which used to be Charlie Brown at where I live and also I know the people which should not be too much trouble. If any parts do need replacing would that be covered under the warranty.
    Quote Originally Posted by hothatch View Post
    If the condenser has been damaged by loose chippings, then no as classed as an act of god.
    Things like pipes and the compressor generally are covered, as long as the pipes don't show signs of any impact damage.
    Merseyside
    Mine has been nothing but trouble. 3 weeks out of warranty and the condenser packed up. Seriously expensive. Get it into Vx whilst you still have a warranty!
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Talking
    Thanks everyone,
    My air con problem seems to be sorted now after a regas, checked for leak with their machine and no leak found. Not sure why it needed a regas being just over 2 year old car.
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Working out MPG
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2011, 10:51
