Results 1 to 10 of 14
Thread: Rear brake pads wearing quickly
    Jun 2007
    Cheshire
    Default Rear brake pads wearing quickly
    Is it normal on a Vec for rear brake pads to wear faster than the fronts?
    Not found that to be the case with previous cars but it seems to be happening on mine. Or is it normal for them to be approaching the point of replacement after 30,000 miles?
    Only came up today as it's in for service so they've rung me to offer to replace them now for only £88
    I'm wondering now if they're rubbing which would explain why my car has always felt a bit more sluggish and 'heavy' than I'd expect.
    On another note, can anyone tell me how hard they are to replace my self if I source the parts. Do I need any special tools?
    Glasgow
    For them to need replaced about 30,000 sounds as if you really have had your moneys worth from them
    You would need a special tool to do the back brakes to rewind the piston into the caliper, it does'nt cost much and if your confident of working on brakes then go for it.
    £88 sounds about right 1 hours labour and the price of cheap pads it sounds like.
    Sunny Dartmoor
    Vec's rear pads wear out lot quicker than the fronts yes,but to get 30k out of them isn't too bad imo,i'd check to see if the piston move's freely,could've been sticking,there is a special tool to do them but apparently doen't fit that well,good luck m8........
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Mine seems to eat front pads, but i do quite alot of miles, think its only had once set of rears since i owned it and ive done over 60k in 2 years.
    Replacement of the pads is a very easy job only special tool you will need is something to wind the pistons back in, you can get a special caliper wind back tool, dont think they are too expensive, or have heard of more diy methods invloving pointy nose pliers.
    Jun 2007
    Cheshire
    Thanks for the replies. Always been easy on brakes so 30,000 not really anything to write home about. If others have found rears to wear quick prob nothing out of order then.
    Just had a quick look for cost of brake rewind tool and it's £45. Coupled with the cost of the pads doesn't seem much point in doing it myself!
    Regular Member Readster's Avatar
    Plymouth
    Steve, They are cheaper than that. £25 at Halfords, Look on ebay for the VX adaptor £8. I've used the rewind tool on other cars since, so its handy to have.
    Cheers,John
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    where are you in cheshire matey ive done pads on mine without any probs think pads are about £20 i'll fit them for you for a few beers
    Regular Member wardy's Avatar
    Chichester
    my rears went at about 40,000. I'm still using the original fronts now at 50,000, although the garage has said that they are starting to get low. Pretty good really. I think I'll stick to the VXL pads if they last this long
    I get about two sets of fronts to each set of rear pads
    Jul 2006
    Newbury
    Just had my 1.9 SRi Estate serviced last week at bang on 50k, they said that the fronts were 50% left and the rears were 10% left. Probably look at doing them myself all round in another 5k or so, and these are the originals from new,
  1. rear brake pads
    By waynevvti in forum Suspension, Wheels & Brakes
    Last Post: 9th April 2012, 16:17
  2. Rear Brake Pads
    By Das in forum Suspension, Wheels & Brakes
    Last Post: 3rd October 2010, 13:15
  3. Brake wearing in time
    By Adz86 in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2009, 11:08
  4. Which rear brake pads?
    By Toyotacelicagt4 in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2009, 13:44
  5. Rear Brake Pads
    By cp123 in forum Suspension, Wheels & Brakes
    Last Post: 24th May 2009, 13:15
vectra c brake pads wearing fast
