Results 1 to 10 of 13
Thread: Just bought an EGR valve for the CDTI 150
    Birmingham
    Default Just bought an EGR valve for the CDTI 150
    Guy's, I have just bought a used EGR Valve off the bay, the description reckons "ITS HAD A VX REWORK ..... THE VX REWORK IS TO STOP THE EGR VALVE STICKING INTERNALLY WHICH CAUSES POOR ACCELERATION, POOR STARTING AND THE DPF BLOCKING".
    Never heard of a Vx rework, so lets leav it to chance....what you think?
    £25.00 ......... hope its the answer to the problems!
    Bye bye Vec B
    - Hello Siggy!
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    Its in the how2's on here. The Vx rework is to remove the solenoid clean and grease up the internals and refit it.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Birmingham
    Is that a good thing its been done then?
    Bye bye Vec B
    - Hello Siggy!
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Sounds like a decent buy. I read somewhere that VX have introduced a modified gasket design which allegedly reduces the EGR from getting sooted up so much. May be worth fitting the new type gasket when you come to swap it over.
    Regular Member old cruiser's Avatar
    slough
    Sounds like a bargain mate,so long as it works!!
    Cheers Pete
    Birmingham
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    I hope so....knowing my luck it will be scroooged!
    Bye bye Vec B
    - Hello Siggy!
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by Cameron43 View Post
    Its not a Vx gasket, its actually Fiat's so you'd need to get it from there.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Quote Originally Posted by Vaux-Man-G View Post
    It'll be fine mate, what was the seller (just out of interest) - its probably the same one I bought mine from, and mines been perfect since
    Birmingham
    Quote Originally Posted by plasma View Post
    I asked this question before but no body has tried it so im a bit cautious about being the guinea pig!! Unless anyone can come forward and confirm they have tried it?
    Bye bye Vec B
    - Hello Siggy!
    Apr 2008
    In UK
    I've seen one or two of these being offered with new EGR valves on Ebay in the past. From what I read they have just made the openings smaller so that I assume it recycles less gasses, thereby reducing the frequency that it needs cleaning. IOW they are using the gasket material to partly block off the ports a wee bit.
    TBh I thought you could get these modified one's from your VX dealer. (but I may be wrong)
  1. just bought 1.9 cdti 150
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2012, 12:29
  2. I Just Bought an 04 CDTi SRi
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2011, 16:25
  3. newbie just bought an sri cdti!
    By renton608 in forum Introduce yourself.
    Last Post: 9th January 2011, 12:58
  4. Bought a SRi CDTi XPII Nav
    By R2XPT in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2011, 09:30
  5. Just bought SRi CDTi
    By POAH in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2006, 14:42
