Results 1 to 10 of 18
Thread: Mis-fire hesitation 1800 -2000 rpm cdti 150
    Regular Member Diesel Dude's Avatar
    Norfolk
    Default Mis-fire hesitation 1800 -2000 rpm cdti 150
    Every now and then when accelerating I get a hesitation at about 1800 - 2000 rpm only on light throttle if I accelerate hard its ok but it doesn't do it every time maybe once or twice on a ten mile trip, any idea's? its on a 2006 cdti 150
    Merseyside
    Could be a clogged up EGR valve or the Swirl valves. Have a search for both on here and see what you think
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Sounds like an airflow issue? Bust hose or bust intercooler. Other issues could be throttly body but more likely to be air escaping.
    Gazza4
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    sounds like 3rd injector plug to me
    , i got same prob
    llantwit major
    have a look at the 3rd plug on the front of the injectors and see if it has been fixed before like mine has
    Jun 2009
    Dublin
    I kind of have this aswell mines in 5th and 6th when i accelerate it kind of feels like an auto changing gear but not as extreme
    Mines a 1.9 CDTI 120
    Still under Net Q Warranty so i'll be taking it back in to get it checked
    Jul 2009
    hertforshire
    I have the same problem i booked it in to nationwide autocare in cambridge and they plugged it in to computer and said there is not fault registering so they cant fix it (under extended warrenty)... they also said that it was ok on the test drive and they couldnt feel any missfire...when i went to pick the car up it did it again...mine even does it when im on motorway changing 5th to 6th at around 70 and has even done it at 80mph... makes me laugh that they cant fix somthing cos the computer says there is nothing wrong with it ???? the guy must obviously think that vecs come standard with missfires.
    Jun 2009
    Dublin
    Quote Originally Posted by Deano.56 View Post
    ...mine even does it when im on motorway changing 5th to 6th at around 70 and has even done it at 80mph... .
    Thats exactly how mine is
    Gonna phone the dealer today, I'll let you know how i get on
    Mar 2007
    Bristol
    mine's doing the exact same thing - booked in to the stealers on thursday - let's see if they have the ability to diagnose and rectify.......
    jilava
    Mine did it when accelerated slowly in 3rd gear at about 2k revs. I cleaned the egr valve and solenoid and now it's OK.
  1. Hesitation 2000-2500Rpm
    By Aidi in forum Engine & Drivetrain
    Last Post: 15th February 2012, 21:47
  2. hesitation between 1500-2000 rpm
    By doggydoctor in forum Engine & Drivetrain
    Last Post: 28th July 2011, 10:42
  3. Cdti Hesitation At 2000 Rpm
    By CRAIG in forum Engine & Drivetrain
    Last Post: 9th October 2006, 13:29
