Thread: Running Temperature 1.8 vvti SRi???
    Jul 2009
    confused Running Temperature 1.8 vvti SRi???
    Hi,
    Recently got a 1.8 SRi Vectra and have noticed it's normal temp when warmed up is 92-93 ish and was wondering if anyone elses runs at that temp? It is never any less than this when warm.
    It's had it's first service so all levels should be ok.
    Is 90-93 ok for normal running temp on the 1.8?
    Admin make a poll please
    11 Post(s)
    The gauge is only a visual indicator (ie, it's not calibrated). Some read slightly lower than 90, some slightly over. As long as the cooling fan kicks in by 95 deg then it's fine.
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    yeah mine indicates 90 when on petrol and 92 when on gas
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    Mines smack bang in the centre of the dial when fully warmed up and sits there all day until you turn off the ignition.
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    Quote Originally Posted by DurhamRed View Post
    ditto
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    About right, compared with my non VVT.
    Mine will drop as low as 80-82, on steady cruise in colder weather though. Only to go up again when back on the gas.
    Darlington
    Mine just sits just to the right of the centre mark, only very slightly though, it sits there happy as larry all day
    Oct 2007
    Shropshire
    Mine old vvt ran at 95 (I checked with a thermocouple as I was concerned it was high and the guage is surprisingly accurate) but that broke at 33k so what does that mean? The new one I got out of an astra runs at a smidge over 90 though. Much better...
    Regular Member luckyluke's Avatar
    May 2008
    S'port and L'pool
    Quote Originally Posted by bigrory1986 View Post
    My indicates more less the same. Interestingly, when in 'test mode' my computer shows 102-107*C
    BTW - What is wrong with 90-93*C sort of temperature?
    May 2007
    Quote Originally Posted by luckyluke View Post
    mine has been as high as 103 on test mode.
  1. CDTi 150 Running Temperature
    By tony-1977 in forum Engine & Drivetrain
    Last Post: 28th March 2012, 11:38
  2. What is the normal running temp of 1.8 VVTi
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2010, 18:47
  3. coolant running temperature?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 13:24
  4. Engine coolant not getting to running temperature
    By richard1707 in forum Engine & Drivetrain
    Last Post: 11th August 2009, 23:19
  5. 2.0 DTI Water Temperature? Running cool?
    By StephNET in forum Engine & Drivetrain
    Last Post: 6th September 2008, 11:08
astra h 1.8 vvt correct running temp
wat is the running temperature on a vauxhall vectra sri 2008 petrol
2006 vauxhall vectra 1.8 correct temperature
operating temperature for vvti engine
vauxhall insignia 1.8 sri temperatura
vectra c vvti resonate from engine compartment
what is the running temperature on a vauxhall vectra sri 2008 petrol
