Thread: HELP!!! Engine Management Light has come on
    northampton
    Eek HELP!!! Engine Management Light has come on
    Hi guys
    I know this is a silly question, but what causes the engine management light to come on?
    The car seems to be running fine...
    Please Help!
    Regular Member AdeyCorp's Avatar
    Chesterfield
    Can be alot of thing, u need a error code. Follow this thread http://www.vectra-c.com/forum/showthread.php?t=81742 that will help you know the problem is.
    northampton
    thanks mate, will try this in the morning, hope my car gets me home tonite
    Note, the DIY fault code trick doesn't work on all Vectras.
    Regular Member Swaite53's Avatar
    South Wales
    You should really get the code(s) read one way or another so you know what the problem (if there is one) may be, but if you don't wish to, you could try disconnecting the battery for 10 mins. This will clear any stored codes.
    Sometimes a glitch can cause the light to come on, and there may not actually be a problem. If the light remains out, then there is no problem; if it comes back on, then there is.
    northampton
    hey all
    I tryed to get the codes up myself... no luck.
    Shes been booked into the garage on friday morning for a diagnostic test... I hope its nothing expensive.
    I dont think I will be getting another Veccy.
    Thanks for all your tips, I'll update you Friday Evening
    Jun 2009
    South West
    Sometimes the eml light comes on for a short period for varios reasons like riding the clutch and little glitches in the cars running. As you say it does not put car in limp mode there is nothing to serious wrong. I had two vectras dti that when I was going over a viaduct on the bypass the eml light would come on that was down to air pressure.
    By Shadrack in forum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
