Thread: whistling 1.9 cdti
    Jun 2009
    northern ireland
    Default whistling 1.9 cdti
    hi is it normal for the 1.9cdti to make a whistling noise will in the turbo rev range...it can be quite loud at times (for approx 2500rpm till bout 3500rpm) and also you can hear the car waste gating as if you had a dump valve on it.........any thoughts......
    Regular Member veccyjim's Avatar
    Mid Wales
    yup thats normal, mine does it too, tho i have a K&N panel filter, de-restricted airbox and thurlby hoses
    Jul 2009
    manchester
    Smile
    Yes mine does the same.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    mine only does it only when its cold??
    Regular Member scottyd's Avatar
    paisley
    mine does it but im taking it to be looked at as its much louder than my old car and i can hear it inside with windows down and couldnt in old car unless theyve taken some soundproofing out
    Regular Member samngeorge1985's Avatar
    lanark scotland
    as with mine i think its normal
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Mine does it too, even more so with the induction kit mind, its awesome !!!
    Regular Member djr69uk's Avatar
    Midlands
    totally normal! mine whistles like a bird in the mornings.
    Wales, UK
    Normal turbo sound on the CDTi - I like it !!
    Regular Member xrken's Avatar
    northampton
    rolleyes
    this is not normal as mine did it just before the turbo went
  1. CDTi Z19DT whistling/ sqeaking noise
    By 123rado in forum Engine & Drivetrain
    Last Post: 20th March 2012, 16:18
  2. What is that whistling noise....
    By baldieone in forum Vectra C / Signum Troubleshooting
    Last Post: 21st March 2011, 10:15
  3. Whistling CDTI 150
    By davidh in forum Engine & Drivetrain
    Last Post: 12th July 2009, 14:43
  4. whistling noise
    By fizler316 in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2009, 16:22
  5. Diesel (CDTi) Whistling Noise
    By Dazza_CDTi in forum Engine & Drivetrain
    Last Post: 10th December 2005, 04:42
