Thread: retro fit fog lights???
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Default retro fit fog lights???
    has anyone on here retro fitted fog lights without using a relay?????
    grimsby lincolnshire
    not sure about using the relay but there is a how2 for retrofitting some fog lights. hth
    Apr 2009
    aylesbury
    Unhappy retro fit fog lights
    in have retro fitted fog lamps on my vectra c 55 plate on a 6 chassis
    the car is a life model and as standard didnot come with fog lights or multi info display.
    i purchased the correct fog lamps, bezzels and lighting switch new from the main dealer.
    all the wiring was there to plug it all in and using tech 2 anything and everything to do with the fog lights were switched on but the front fog still don't wanna play ball
    any suggestions i read also in this post something about a relay??????????
    help im going mad,
    on another note take the tid (triple info display) and replace with a mid (multifunction info display) and get it programmed with tech 2 works a treat just as if it had been fitted as standard
    thanks guys
    dabve
    Full Member Robsey's Avatar
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    A very old thread resurrected but,
    Has anyone achieved this?
    I tried to advise a fellow member on here about retro fitting front fogs via the under hood electrical centre. He wired everything up per TIS, however he never got it to work.
    The wiring diagram on TIS does not mention anything to do with a relay. (reading the last post)
    All it touches upon are
    Fit the correct light switch,
    Connect up the link wires from the UEC to the fogs.
    Then program the UEC and Instrument panel... not sure if the BCM needs to be told to expect a fog light button actuation signal.
    Wiring for those without the wires in the big fat conector are
    UEC connector XE2 (The big one with approx 50 pins)
    XE2 pin 10 to left front fog - black wire
    XE2 pin 37 to right front fog - black wire
    Front fog return wire - connect this (brown wire) to same coloured wire on the headlamps or the horns, as these are all grounded to the same pin on the UEC. (pin 18 or 21.. cannot remember which at the moment).
    As said above - I cannot find any details about a relay nor fuse for the front fogs.
    Although I did get one from Vauxhall for about £7 about 5 years ago, after asking for a front fog light relay.
    Any updates on this thread, or do I need to use my wife's 2005 Vectra Energy as a guinea pig.?
    Currently I have wired her front fogs via a relay, and a rocker switch built into the light switch assembly,
    however I plan to retro fit auto lights with rain / light sensor and auto-dimming mirror. I don't really want to hack the new auto-light switch assembly to transfer the rocker switch across.
    Apologies for the war and peace, but like to give all the facts.
    Regular Member LGaffer's Avatar
    Dec 2012
    Castleford
    5 Post(s)
    Vehicle : Vectra C Preface
    Trim : SRI
    Engine : 1.9 cdti 150
    @Robsey or anyone else, did you ever manage to fathom this out? I'm wanting to add fogs to the better halfs estate
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    138 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    You need a compatable UEC & BCM and obviously a foglight switch and the wiring, but I've programmed a couple of users add on foglamps without the need for any relays.
    Can't be done with opcom, you need vauxcom or tech2 to do it.
    Woody's Vx Ice Addons UK/Eire Distributor of the Comfort Unit and Video Accessories from www.PepaS.cz Designed to enhance your Headunit & Display these add in Additional Data and Reversing Camera & Media. NOW INCLUDES FULL Vxr/OPC NEEDLE SWEEP & LIGHTS Also CD70 Aux In & 3 Line Display Updates.
    Quote Originally Posted by LGaffer View Post
    Have you seen the HOW2?
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by Woody View Post
    Yes I did the full factory retrofit. Its pretty much as woody says. BCM should be compatible, even my poverty spec's LS worked fine. But as woody says you need to activate the BCM with Tech2. The main issue is you need to match the UEC to your car. ie if your car is a half can diesel you need a uec from a half can Diesel, likewise if your car is a half can petrol you need a uec from a half can petrol. Best bet to look out for someone breaking an SRi or an Elite. You wont even have to have the UEC activated as its remembers its settings and doesnt need paired to your car.
    Dec 2012
    Castleford
    5 Post(s)
    Trim : SRI
    Cheers Woody, I know the bcm is compatible and have sourced another UEC as I thought that would be needed. It was just the relay situation. I have access to tech2 so thats not a problem either
    Yeah I looked at this but wanted to factory fit them, but thanks anyway mate much appreciated
    Quote Originally Posted by Das View Post
    As above I've got a UEC from a same engine SRI spec car. The bcm supports the fogs, its just the wiring from the UEC to add then as thats not there
    Cheers everyone for your help
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    You may also find that the UEC will behave as if it is not programmable for front fogs,
    BUT
    As soon as you enable the front fogs in the BCM,
    in many cases the UEC suddenly becomes able to be programmed for front fogs.
    The problem with Opcom, is that it is stuck on 2010 software.
    The BCM was not supported until later software releases.
    Obviously true vauxcom is capable of using the latest software release.. December 2013.
    And Tech 2 - well it goes without saying.
  1. Auto-lights retro-fit?
    Last Post: 19th October 2012, 01:09
  2. retro fit fog lights on a facelift
    By N2B in forum Bodywork & Interior
    Last Post: 17th June 2009, 20:44
  3. Retro fit xenon fog lights
    By adfrodsham in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2009, 01:05
retro fit Vectra front fog lights
