Results 1 to 10 of 23
Thread: V6 Diesel - fuel rail pressure issue
    Nottingham
    Default V6 Diesel - fuel rail pressure issue
    Just has diagnostics back from Vauxhall on my 3.0CDti and they have a 'fuel rail pressure' error.
    They are saying that a New suction valve kit may cure it (about £500 fitted) but there's no guarantee it will work in which case it will need a new fuel pump £1,557 +VAT
    Problem is that if I go for the suction valve kit and it doesn't work I'll end up paying for the labour twice.
    Can anyone offer any advice on whether the suction valve kit is likely to work or any other wise words?
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Vauxhall once diagnosed mine as having low fuel pressure, they had the car 5 weeks then told me it MIGHT be the fuel pressure switch about £1000 fitted but they couldn’t guarantee that it would fix the fault, I agreed and it didn’t fix the fault, they then gave me an estimate of over £10,000 to change all the injectors £585 each the injection pump £2134 & the fuel rail £1315. Car has been sat on my drive ever since, starts and runs but smokes like crazy.
    Nottingham
    Thanks. Now you've really cheered me up
    Mar 2007
    Stockton on Tees
    Whats was wrong with your in the first instance?
    I took mine to the dealers because of the amount of black smoke it was producing?
    Nottingham
    car stuttering under acceleration and then the spanner light comes on. Done it 4 or 5 times during last week but then clears once engine warm and ignition switched off and on.
    Mar 2007
    Stockton on Tees
    Sounds a totally different fault to mine, i have never had the spanner light, think thats whats confussing the dealer, well the fact they cant just plug a computer in to find the fault. Hope you have a better outcome than mine.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by Phil View Post
    Have you tried some injector cleaner mate?
    Not sure if the egr would have anything to do with it as its only happening when cold.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Is there a loss of power when it stutters? Mine sometimes stutters under light acceleration when cold. Get's better when it warms up.
    r.bailey63 when does your car smoke? Only on acceleration or all the time?
    Mar 2007
    Stockton on Tees
    Just on acceleration.
    Nottingham
    loss of power under acceleration and then picks up again but spanner light comes on. Switching off ignition resets light and usually doesn't come back on again.
    Haven't tried injector cleaner. How does that work? Is it something you add to the fuel?
    The fault has been diagnosed as requiring Vauxhall Field Remedy 1957 !! 6 hrs labour to replace a solenoid (£96 +VAT part) in the fuel pump with no guarantee of success and then if it doesn't work another 6 Hrs labour to replace the fuel pump and the cost of the fuel pump is £1,557 + VAT
    Thinking through my options
  1. Fuel Rail Pressure Sensor - another thread
    By Stevo2 in forum Engine & Drivetrain
    Last Post: 30th June 2010, 20:52
  2. Fuel Rail Pressure sensor
    By RobW in forum Engine & Drivetrain
    Last Post: 3rd December 2009, 16:55
  3. P1191 - fuel rail pressure sensor circuit low input
    By L11Marc in forum Engine & Drivetrain
    Last Post: 17th March 2009, 17:12
  4. Diesel - fuel pressure ?
    By Led in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 15:24
Y30dt fuel pressure sensor connection
