Results 1 to 10 of 24
Thread: How to clean the throttle body of CDTi 1.9?
    North East
    Default How to clean the throttle body of CDTi 1.9?
    Can someone please tell me the best way to clean the throttle body of a 1.9 CDTi SRi [150].
    Is it an easy job? and how do I do it?
    Michael
    Regular Member Readster's Avatar
    Plymouth
    I have a 1.9 120 CDTi and had to have the throttle body replaced last week.
    No cleaning option according to VX.
    If you have time maybe a used unit could be sourced?
    Regular Member Pete B's Avatar
    Malvern
    Quote Originally Posted by Readster View Post
    Did you get yours back to try on or did the dealer dispose of it?
    It could make an interesting experiment - Vx will always take the official way out & it's probably cheaper for them/you. For the Dealer mechanics to clean such an item would probably cost as much if not more in labour & wouldn't have any warranty whereas the new part does if it goes wrong.
    The now nearest 'local' Vx dealer after the demise of Bicknells strongly advised me against cleaning the EGR but I did so without any issues, just as many seem to have done on here.
    PS How's the holiday going?
    Plymouth
    Hi Pete,
    We are off next week. Fingers crossed for better weather
    The dealer retained the part...to be honest it never occured to me to ask for the old one
    I had a Mitsubishi with throttle assembly issues some years ago, and while a 'sonic clean' brought a few more miles at the end of the day it had to be replaced.
    Costwise? I may have just replaced it first as last and saved the cost of the 'sonic clean'..
    I applied the same logic to my Vec.
    I'm surprised that these EGR valves & throttle body & swirl valve problems occur as offer as they appear to on modern motors
    Could it be a built in problem?
    I am doing up a '89 Metro with Readie Junior in time for the 30th do's in 2010. I look fondly at A series simplicity and functionality.
    Never mind...can't live in the past eh
    John
    Regular Member kevdsissi's Avatar
    oldham
    hi mpc had the same fault code as youhttp://www.vectra-c.com/forum/showthread.php?t=87701 Monday purchased the throttle body
    to day and Ive taken the old one apart and it was full of old oil
    and I am sure it should not be
    Attachment 23953
    Attachment 23955
    Attachment 23956
    and now you see the printed circuit board
    Attachment 23957
    Attachment 23954
    Plymouth
    That's exactly what the VX dealer said 'full of oil'.
    How on earth did it get in there though...
    No chance to clean yours out Kev?
    oldham
    local vx dealer had 4 on the shelf common fault, had I known how easy it was to take apart I would have cleaned and put back on and tried, but I will now put it on the shelf till next time ,just hope this helps some one else in the future
    Plymouth
    Sounds a good idea to me.
    I'll put that as a 'solution' in my e tool box
    Farnborough, Hampshire
    Hi, what would you use to clean the oil? was going to attempt cleaning TB soon and would have been least impressed to see that oily mess...so now im prepared ;-)
    oldham
    just emptied the oil out and wiped out with rags never refitted as I had purchased a new one only took the old one apart out of curiosity
  1. Clean throttle. Body
    By daddy5times in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2013, 20:17
  2. egr / throttle body clean at 45K
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2011, 16:23
  3. DTI Throttle Body Clean
    By si_hoss in forum Engine & Drivetrain
    Last Post: 7th July 2010, 13:37
1.9 cdti throttle body cleaning
Opel vectra c throttle body
vectra c throttle body full of oil
z19dt throttle body
zafira 1.9 cdti egr throttle body
opel 1.9 cdti kaasuläppä
vauxhall 1.9 throttle body cleaning
vectra oil in throttle body
Vectra c yhrottle body circuit
throttle body cleaning opel opc
zafira b 1.9cdti 150 throttle
z19dt throttle bodie
vauxhall insignia cdti throttle body location
best way clean throttle body on vauxhall vectra
opel vectra c throttle valve clean
vectra throttlebody oil
vectra c 1.9 cdti throttle body
vectra cdti 150 throttle body
vauxhall vectra c cdti sri throttle body clean
vectra c throttle body cleaning
how to take a part vectra c 1.9 throttle body
1.9 cdti throttle body full of oil
show vectra c 1.9 cdti throttle body electronics
throttle valve body circuit ful of oil vectra z19dt
oil in throttle body vectra
