Thread: Inlet manifold on Vectrc C cdti
    Jun 2009
    wolverhampton
    Default Inlet manifold on Vectrc C cdti
    Hi Guys,
    I have a 2004 CDTi 150 which has been getting the spanner light coming on every time I go over 60 mph, I had the engine checked and found the bar that runs across the swirl valves had come away.
    Is there any way to repair that rather than have to replace the whole inlet manifold??
    If the manifold does npeed repalcing, is there anything else that needs changing along with it at the same time???
    Full Member Big Sig's Avatar
    Oct 2007
    Ripon
    Did you try the repair?
    Jun 2009
    wolverhampton
    I tried the suggested repair but as soon as the engine was revved, the rod flew off again.
    I ended up having to replace the inlet manifold along with the actuator motor at a cost of £500 inc fitting.
    Car is working fine now, better performance and no light...but it does still seem to judder at about 30ish when between 1500-2000 revs.
    I don't think it is the egr valve because i have cleaned that out so i'm wondering wheter it is the throttle control??
    Wales, UK
    Could be the 3rd injector wiring fault ??
    Jun 2009
    wolverhampton
    How do I go about changing that??
    Oct 2007
    Ripon
    There is a How2 .... When get a chance i'll have a nose.
    Been quoted £485 for new manifold .... the ball joints are very badly worn on mine with the holes on the Bar being almost worn to the edges.
    Jun 2009
    wolverhampton
    I was quoted £400 inc vat for manifold from local VX dealer but i managed to get it at trade - 10% off.
    Problem is that if you change manifold the motor also needs changing - bumping up the cost!!
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I gave Chris my spare manifold
    reson the bar usually breaks off is the swirl valves get clogged and jam. If you remove and clean the manifold and then refit the bar it may be fine but it's a big job. On chris' the swirl valve was actually moving in the housing and leaking pressure so the manifold had to be changed.
    It's a big job to remove the manifold so read up if you are going to do it yourself.
  1. Inlet manifold 1.9 cdti 150 help
    By Mads in forum Engine & Drivetrain
    Last Post: 1st October 2011, 21:55
  2. CDTI 150 inlet manifold
    By jacko52 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2010, 13:32
  3. 1.9 CDTi 16v Inlet Manifold
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 24th September 2008, 20:22
