Thread: Time for plan b
    Mar 2007
    North East
    Default Time for plan b
    Had some spare time since the kids are away at the outlaws, so I decided to fit a rear power socket in the boot.
    Removed the side panel to get a look at the rear fuse box so I could find a permanent 12V. Plenty of spare fuse ways and permanent 12V however the fuse ways have no sockets..... what a pain in the bottom . Would mean removing the fuse box and some soldering, not going to happen on a new company car.
    Oh well, plan b, run feed from battery compartment to the boot, that's for another day.
    Regular Member scottyd's Avatar
    paisley
    buy pins from an auto shop and make a plug mate or tap into an existing fuse
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Can't you just jam a wire in with a fuse holding it in lol
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Maplins do a nice little socket.......
    Take out a fuse, put the adapter in and put the fuse into the adaptor, then wire to the adaptor.
    Mar 2007
    North East
    Had though about getting a piggy back connector from maplins, but a quick prod with the meter shows that most of the permanent lives are fed via the bigger squareish 30A fuses and I don't think the piggy backs fit those.
    It seems that most of the others are "switched" via can.
    Not sure about dismantling the fuse panel to add some extra sockets as it's a company car. Though I might have a look to see what bits are needed to do the job.
    paisley
    tap into tail light wire mate and put a seperate switch init then when you want to use it just put sidelights on. hth
    Mar 2007
    North East
    Well had some time today (thanks to being called out in the early hours ). There's a pin in one of the empty plug sockets which is a permanent live, big enough to fit a red spade onto .
    Still thinking about whether to take the fuse box apart or to run from the battery.
    Mar 2007
    North East
    Quote Originally Posted by scottyd View Post
    Might have a look at that.
  1. The plan
    By bobssignum in forum Comedy & Humour
    Last Post: 30th March 2012, 10:57
  2. The detailing plan!
    By cont1204 in forum Detailing and Car Care Discussion
    Last Post: 30th March 2012, 07:29
  3. Is the master plan about to pay off????....
    By Vectralicker in forum General Chat
    Last Post: 4th September 2011, 09:13
  4. So what's the plan?
    By Stevel in forum General Chat
    Last Post: 15th February 2008, 17:31
  5. Change of plan....
    By BigMan in forum General Chat
    Last Post: 31st January 2008, 11:17
