Thread: Throttle response
    Regular Member old cruiser's Avatar
    slough
    Default Throttle response
    Notice from time to time on motorway , that if I come off throttle then back on fairly quickly as it were, I sometimes get a glitch in response, as if it misses a beat , mainly noticeable when in third gear; did do the AirBox Mod' and put the shorter VXR intake pipe on and also blanked off the EGR valve doing all these has improved the car from what it was and got rid of the hesitancy I did have, particularly in top gear , but now beginning to wonder if I would be better off putting the longer intake back on or not, what do you reckon guys, just wanted the advise before fitting it back on (or not as the case may be)and wrecking my knuckles again!!
    Cheers Pete
    Regular Member Readster's Avatar
    Plymouth
    Maybe the hesitation you describe is down to faulty injectors more than the airbox.
    Have you tried a fuel system cleaner ?
    Just a though..
    slough
    Quote Originally Posted by Readster View Post
    Just a though..
    Good point mate, haven't recently, last time I used some redex, but that was nearly a year ago , so maybe time for some more or something similar.
    Cheers Pete
    Plymouth
    Be interested to see how you get on.
    I put the airbox back to standard after my Vec's throttle assembly shambles.
    I still don't know if its a tangible benefit to remove the plastic shield in the a'box.
    How did you blank off the EGC valve?
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Quote Originally Posted by old cruiser View Post
    Please let us know
    slough
    Used a blanking plate with new gasket and fitted a cheater (which mimics the egr to stop mil light coming on) purchased cheater from Vocky on Z22SE site, cheater I think is only needed on the Z22SE engine, I did find that by removing the trumpet in air box made a difference to mine for sure in that it smoothed out the rev range. Getting back to injector cleaner I think it might have been Greased lightening fuel treatment I used as opposed to redex!
    Cheers Pete
    Plymouth
    That'll save a lot of grief not having a EGC valve Pete.
    Too many gizmos
    I may redo the AB mod, see how I get on...guess I don't want to think that playing about wrecked the throttle assembly that's all...
    I got the injectors on a Ford diesel cleaned by a diesel specialist who also tested them. That may be another option to consider.
    John
    slough
    Too many gizmos
    John
    You're right there John about too many Gizmos, the EGR is not a requirement in this country anyway and one of the things Vx dealers do is to remove the EGR e.g on the Z22YH engine for those that are playing up and do as I did and blank it off and reprogram the ECU to disable the Valve and was removed completely as of May '06 on these engines!!. If you do the airbox mod' make sure it's the trumpet part under the filter that you remove and not the one in the upper lid as this one can affect/ damage the maf sensor and BTW thanks for the heads up on the Injector cleaning.
    Cheers Pete
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The hesitancy is mapped in I think Pete. Its not like the old cable actuated throttle. It was the first thing I noticed when I bought mine. If you have the sport button it alters it to a more responsive pedal along with the steering and stiffens the suspension.
    How did you blank off the EGR valve?
    I'll be doing a How 2 for blanking the EGR guys. It only works on the 2.2 petrol though.
    slough
    Ah right that makes me feel a bit better about, if I go back on the throttle gently it's ok so must keep doing that I think! so basically fitting the longer intake back on won't really make a difference to this issue then, so may just as well leave it with the shorter one on I guess.
    Cheers Pete
  1. Bad throttle response
    By Hodgy in forum Engine & Drivetrain
    Last Post: 6th February 2013, 19:21
  2. No throttle response Cdti 120
    By Vectra Meldrew in forum Engine & Drivetrain
    Last Post: 1st August 2012, 13:05
  3. Bad EGR and no response from the throttle 2,0 DTI
    By ldanieli in forum Engine & Drivetrain
    Last Post: 13th February 2012, 19:38
  4. intermittent throttle response
    By helisurf in forum Engine & Drivetrain
    Last Post: 21st December 2011, 22:06
  5. No throttle response on 3.0CDTi
    By Celes in forum Engine & Drivetrain
    Last Post: 26th July 2009, 10:35
