Thread: Front shocker
    Regular Member biglee55's Avatar
    wolverhampton
    Default Front shocker
    How easy is it to change the front shocker, mine has gone on my vxr and vauxhall want £270 to change it.
    norn iron
    easy, you can get a decent pair for bout 100 quid, could change apair in less than an hour, so basically
    go somewhere else...
    norn iron
    oops didnt realise it was a vxr though!!
    Regular Member brianjamesreed's Avatar
    N Ireland
    Default replacement shocker
    Havent done a VXR but changed the springs on a DTI.
    Assuming they are very similar then the strut and hub unit can be sepparated without having to split CV joints or break calipers.
    I had great difficulty loosening the nut at the top of my strut. The only way I could shift the nut was to hit it with an air-driven impact driver. Just a couple of short squirts until the nut moved but don't loosen it totally as you need to compress the springs. I did it with the struts still in the car and only then did I remove the struts and compress the springs.
    The job is very straight forward if you have the knowledge and the tools. Failing that see if you can get a local mechanic to do it. Should only be about an hour or two labour and certainly a lot safer.
    BE WARNED --- IF A SPRING SLIPS AND GOES FLYING IT COULD CAUSE SERIOUS DAMAGE AND INJURY, EVEN DEATH.
    BJR
    wolverhampton
    Ok thanks for the help I won't be trying this myself lol :O)
    Regular Member the fisherman's Avatar
    manchester
    its quite simple to do mate if you have the tools
    Surrey
  1. Anti roll bar link, and front shocker
    By davedave in forum Suspension, Wheels & Brakes
    Last Post: 6th May 2012, 06:03
  2. Leaking shocker?
    By spukeyyy in forum Handling & Braking
    Last Post: 16th June 2011, 19:24
  3. A right shocker!
    By bigknill in forum Handling & Braking
    Last Post: 14th July 2008, 08:34
  4. Bit of a Shocker, even for TFL!
    By VXR_DV in forum General Chat
    Last Post: 1st May 2008, 10:19
