Thread: Does anyone know how to change F35 gearbox oil?
    Hertfordshire
    Default Does anyone know how to change F35 gearbox oil?
    I want to change the oil in my gearbox as it sounds like its running a bit dry.
    Having trouble locating where the plugs are. Have heard a few people say that there is a dipstick but have found out this is only on auto's and I have a manual gearbox.
    I want to drain the old oil out and put new stuff in.
    Jun 2009
    South West
    The Fill plug is the top of the gearbox your may have to remove battery box to get to it. There is no level plug you just have to put in what Vx recomend.
    Jun 2009
    South West
    Hi got that wrong. level plug is behind drive shaft inner housing left hand side. you have to fill gearbox throught reverse light on gearbox until oil is at lover level on level plug as normal gearboxes.
    Regular Member shadow.warrior's Avatar
    Jul 2009
    Melbourne
    i just spent half the day trying to figure it out myself.
    for anyone looking for the info in the future, here it is:
    i found this pic on a sab forum which seems to be acurate:
    the link to the post: http://webcache.googleusercontent.co...&ct=clnk&gl=au
    be warned though, the sump plug is very close to a chassis rail and theres not enough room to get an allen key in there. i ended up buying another cheaper allen key and sawing it to fit.
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. M32 gearbox oil change??
    By shb1988 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2013, 20:51
  3. F23 gearbox and oil change?
    By Deadman in forum Engine & Drivetrain
    Last Post: 12th December 2010, 18:16
vectra c f35 gearbox
f35 gearbox oil change
f35 gearbox oil
vauxhall vectra manual gear oil change
f35 gearbox oil check
