Thread: 2.0Dti Brakes
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    Default 2.0Dti Brakes
    Guys i need some help i have just had a service and before it went in the brakes were really bad had to push the pedal quite hard to get a responce. so when it went in i asked for them all to be check and the brake fulid changed which they did but i cant see any difference in them. Are the brakes on these cars that bad or is there something else
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Magpie
    sounds like your brake servo isn't working.to test it ,pump brake pedal a few times with engine turned off to release sevo vacuum. press down brake pedal and keep the pressure on the pedal,start engine with the pressure still on pedal,if servo is working right the pedal will drop towards the floor slightly,if it does'nt move check vacuum line non-return vave.
    Liversedge, Westyorkshire
    or just the fact that the vectra brakes dont feel that good anyway! mind i do drive a mini which anchors itself to the spot at the slightest hint of a press on the pedal
    Regular Member bogbody's Avatar
    Jun 2007
    Peterborough
    Vehicle : Astra
    Engine : 1.6
    My ex used to complain that the brakes on my old X-reg Vectra B were no good. There was nothing wrong with them at all.
    She was comparing them to the over-servo'd highly sensitive brakes on her 307. I used to find that the 307 would stand on it's nose with the slightest, lightest touch on the brake pedal. It was difficult to drive smoothly with such over-servo'd brakes.
    In terms of a driving experience I much prefered the Vectra as I found it easier to control with brakes that were much more progressive.
    The Signum I now have has brakes that have more servo action than the old Vectra B but I find that the brakes are fine.
    So you may actually be comparing brakes systems that have more pedal asssistance rather than actually have any fault.
    Check and make sure that the brakes are 100% correct of course!
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. 2.0dti
    By danny1992 in forum Diesel Engine related
    Last Post: 20th December 2010, 17:44
  3. vec c 2.0dti sxi
    By mgp in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2009, 22:57
  4. 2,0dti CAT
    By dervdoc in forum Parts for sale
    Last Post: 2nd May 2007, 14:43
  5. 2.0dti
    By thestaffy in forum Diesel Engine related
    Last Post: 17th March 2007, 14:22
vectra c 2.0dti braking
