Thread: Swap Vectra Door
    Jul 2009
    Waterford
    Default Swap Vectra Door
    Hi All
    I need to swap a damaged door on my car. I have a second hand door that needs to go on but none of the inside panelling came with it. I need to swap all of this over to the new door before I can fit it.
    Can anyone give me some pointers as to where to start ? Should I leave it into the shop to get this done or can I diy it.
    Have a look in the ‘How2’ section, a few pointers regarding changing or up-grading mirror’s for a start hth ….
    Jul 2009
    Waterford
    Smile
    Cheers Tadpole
    I will have a look, I could only spot two torq screws on the inside of the door. I have a habit of breaking things so I will check out the how to's before I go near it.
    Regular Member poves's Avatar
    lancashire
    Just get a mate to help you , and take your time.
    All things on the door panel like grab handle covers and switches pop off , then there are torx screws behind , once these are out the panel is held on by plastic poppers.
    Like I mentioned before , the only tricky thing will be the window regulator ( riveted to the door skin. ) So be sure to have a torx bit set , a rivet gun and rivets , and a drill to pop the old rivets out.
    Take pictures of everything first , then as you go. This will help make sure you get everything aligned and in the correct place.
    It's definately worth a go if your not bad on the spanners. But definately make sure someone's there to help with lifting and aligning the door.
    There's enough support on here if you get stuck with anything , You only need to ask. good luck .
  1. Door trim - swap or wrap?
    By Chris B in forum Styling
    Last Post: 9th March 2012, 20:25
  2. Irmscher door pins straight swap
    By John LE in forum East Scotland
    Last Post: 2nd October 2010, 08:30
  3. To swap auto folding passenger door mirror
    By Ziggy in forum Parts for sale
    Last Post: 24th July 2009, 08:47
swapping vectra c door
