Thread: rear shockers
    edinburgh
    Default rear shockers
    Hi all.
    apologise if the following makes me sound really silly!
    i am going to attempt to renew my rear shocks on2.2dtisxi
    are the bolts easy to spot and unscrew? is it adviseable to change the bolts or will i get away with reusing the old and does anyone have any ideas which is the best make of shock to get.
    many thanks
    graham
    Sunny Dartmoor
    Very easy job to do Graham,re-use the bolts and get hold of some bilstein b4 shocks,thats what i've got on mine and they're awesome,hth..........
    edinburgh
    thanks Glen will let you know. thanks for replying mate.
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    You will need Torx Sockets iirc, top and bottom both different sizes too.
    Very easy job to do though.
    edinburgh
    thanks r bailey. will keep all posted.
    Regular Member dj1's Avatar
    leek
    hi mate, just put b4's on mine, very easy!!, take wheel off, following the shocker up vertically in the wheel arch you'll find a bolt undo this, follow the shocker back down you'll find the second bolt undo this! riggle the shocker from up behind the arch and your done!!. as for the replacments if you go with b4's, i found the cheapest £68.88 inc free delivery
    hope this helps!!!!
    edinburgh
    thanks dj! will do next week if it stops raining!
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Very easy to fit mate, my next mod hopefully
    edinburgh
    done the job many thanks to all posts! job took 45 minutes andnow drives like a dream.
  1. kyb shockers
    By dcm23251981 in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2012, 12:54
  2. rr shockers
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 14:10
  3. rear wobble not shockers or trailing ams
    By sxigaspete in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 20:18
  4. Shockers
    By user999998 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 17:54
  5. rear shockers -need names please
    By cyb in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2005, 19:08
