Thread: Signum Elite steering
    Guyhirn
    Default Signum Elite steering
    Hi chaps,
    I've got an 07 Signum ELite that came with 215/55/17 with ET41 offset on which the steering isn't exactly precise (I've had focus & A3 before) but was OK and i was told that the Vectras/Signum's are like that.
    I've put Vauxhall 225/45/17's (ET41 offset again) on it as they look a bit prettier but the car pulls now with any odd bump, pot hole or whatever which makes it hard work to keep straight.
    So, I have two questions that hopefully someone who knows can help me.
    1) Can i get something(s) adusted to sort the steering out on my new wheels?
    2) Once I've sprted the above, is there a way of sharpening up the steering on the Signums so they're not quite so, err, loose?
    Any help appreciated.
    Ta,
    Nick
    Plymouth
    I suffer from the same problems on the Vec .... the tracking has been adjusted 3 times, wheel allignment twice ... Tyres swapped around,
    Nothings worked... and now its just normal to me
    Regular Member JudgeApocalypse's Avatar
    Apr 2009
    Anglesey
    Hi I have an elegance 2.2dti and as above cannot help. Interesting to know if there is a fix though...
    Regular Member Jezzy's Avatar
    S.E
    215/55/17 (your original tyre size) isn't the correct fitment by the way; it should have been 215/50/17. The 55 section tyre is for the 16" wheel - 215/55/16.
    Jun 2009
    South West
    if you chang the wheels and make the wheel base wider then you will get tracking and you forever trying to keep straight. The only way to sort it out is to find a car with these whells as standard and replace the steering rack and suspension parts to match. All car are produced to run on certain whellbase . If you could fit wider wheels on all cars you would have the same part numbers for every car but the suspension is different on all Vectra C's. even the tie rods on a vectra with 16' wheels a re different to 17'.
    Guyhirn
    Hi Chaps.
    THanks for the responces.
    Big Dar - thanks for the insight. I had assumed that the steering hardware etc of most the 'standard' Vx's would have be the same as it would keep things cheap, but obviuosly not.
    Looks like I'll be swapping thew back then ....
  1. Replies: 6
    Last Post: 9th December 2012, 18:40
  2. Off to look at a Signum Elite. Elite + suspension = GSI?
    By Yugguy in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2012, 10:42
  3. Steering wheel airbags elite/sri
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2011, 20:19
  4. steering buttons on signum 2.2 elite
    By shooters tour in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2010, 16:25
