Thread: Broken Key
    Stockton on Tees
    Default Broken Key
    My neighbour who has a 52 Plate Vec C can't use his key to lock or unlock his car by remote. when he unlocks it with the key the alarm goes off until he turns ignition on (which is annoying as he leaves for work between 0430 and 0530 in the morning!!!) VX told him it will cost £130 to replace his key. does anyone know anywhere where you can get a key that will be set up for his car??
    thanks
    Steve
    11 Post(s)
    I take it he doesn't have a spare key.
    As a work round for now to stop the alarm from sounding, reach in through the rear door and press the button down on the drivers door - then close the rear door. I should point out that not only will the alarm NOT be set, but the deadlocks WON'T be set either.
    Stockton on Tees
    He has lots of keys and has tried different control units (his wife works at a salvage yard and he's been trying keys from Cat A write offs) All his tinkering has led to nothing. His cars parked off road so i doubt he'd leave it un armed. I'll let him know that trick anyway.
    Stockton on Tees
    I went over and had a look at his keys today and fixed 2 so they work. The unlock buttons had both come loose so i removed them, from the other keys he had and fixed them inside the keys designed for the car. works fine now. Thanks for help. Steve
  1. Broken Down!!!
    By e55ex_rob in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2012, 18:35
  2. Broken banks of river = broken vectra...
    By andrew e in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 20:48
  3. VXR Red Broken down on M1 J11
    By Impresss in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 1st July 2009, 19:45
  4. ECU broken need help!!!!!!
    By Morephun in forum Engine & Drivetrain
    Last Post: 1st March 2009, 08:40
  5. No It's Not Broken Again
    By nutron in forum Trax 2008 - 7th September
    Last Post: 7th September 2008, 22:24
