Results 1 to 3 of 3
Thread: Air Con Condenser Part No. Required and How to Fit it
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    Default Air Con Condenser Part No. Required and How to Fit it
    Hello, air con condenser broken so if anyone could supply me with part numbers for the 1.8 vvti 140bhp engine and any seal bits I need I would be most grateful.
    And if anyone could tell me how to change it as well, then I would be just as grateful as I will be for the part numbers.
    Just got a job after 3 months on dole and even though the weather's poor, I still need that cold blast.
    Thanks in advance
    Andrew.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    For the Z18XE, XER, XEL engines, manual/auto transmission, part no 24418362 (Opel 18 50 076)
    You might find a slightly better price on an aftermarket equivalent unit though.
    I used this bunch for the condenser for my old Omega :
    http://www.automotive-air-conditioni...cle-parts.com/
    the part arrived in decent time and was a perfect fit.
    As for how to fit it -not done one of these - refer to Haynes book
    rarely that difficult though if you know your way round a toolkit. Good chance you'll need Torx sockets at some point though.
    Once fitted, down to KwikFit to get it pressure tested and refilled for £45 (or less).
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    Thanks, wasn't sure if the XER and XEL were the same part numbers
  1. aircon condenser washer part number for 1.9 cdti 2006
    By voxvectra7 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th September 2011, 16:26
