Thread: outside temp sensor.
    hull
    Default outside temp sensor.
    hi all,
    could anyone tell me where the outside temp sensor is located.
    mine seems to be giving a low reading, so i presume it's got dislodged or dirty.
    anyone else had this???
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    its clipped on to the front bumper near the passenger side fog light thats where mine is
    hull
    do you have to get under the bumper to get to it then pal?
    lanark
    Year : 2012
    Mileage : 9k
    i think that you might not see it from underneath due to the plastic cover under there i only seen mine when i had to disconect it to take the bumper off but i'm not sure if you can get in from above as everything is pretty tight in there
    Rosyth
    when you open the bonet up look down infront of the radiator and you should see the wires running to it cliped along the bumper grill hope this helps.
    Jun 2007
    Wirral
    Quote Originally Posted by frasedeb View Post
    hi all,
    Hi frasedeb
    I can't see a sensor under reading as it can only measure down to the lowest temperature, but easily
    over-read if near something warm (engine/sun/whatever), could be just knackered I guess?
    neilrj
    Newcastle under Lyme
    mine was connected to the lower grille
  1. Outside Air temp sensor........
    By Mark@Elite in forum Troubleshooting
    Last Post: 4th February 2012, 16:20
  2. Temp sensor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 21:23
  3. Outside temp sensor
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 17:35
  4. Outside temp sensor
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 18:29
  5. Temp Sensor
    By ghostrider in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2006, 22:45
