Thread: water in passenger footwell
    Apr 2009
    leeds
    Default water in passenger footwell
    hello all
    i have got a problem with water in the passenger footwell after all that rain. i have just cleaned the drains near the winder screen. i don't have a sunroof. any ideas where else it can come in. is this a common fault. drying it out now to see if it gets wet again.
    thanks for any help task.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Blocked drain under skuttle panel?
    Open bonnet and on the passenger side there is a flap lift it up and in front of the pollen filter there is a drain check this is not clogged with leaves.
    Gazza4
    Apr 2009
    leeds
    done them this moring m8. just wanted to check not missing anywhere else. thanks.
    Regular Member Readster's Avatar
    Plymouth
    Door seals?
    Window seals?
    Could be after the extreme rain we have had.
    Try sitting in the car with a torch and get someone to hose the car in all areas you suspect may leak and try and replicate the leak.
    Let us know how you get on.
    preston
    I had this problem on various cars and in the main turned out to be the plastic film coming adrift at the bottom on the door panel. The film that is stuck to the door when you remove the door card. This plastic film deflects water away from travelling inside the car, but sometimes gets damaged and leaks.
    West Mids
    I had the same problem and it turned out to be what Gazza4 said, mine was covered in everything . Good clean out and it hasn't happened since.
    Apr 2009
    leeds
    Thanks for the help guys.
    Regular Member Syntax Error's Avatar
    Jun 2006
    Manchester, England
    I've got the same problem on my Signum now.
    I'm gutted, but I'll have a look, although I don't exactly know what I'm looking for.
    Full Member Big Sig's Avatar
    Quote Originally Posted by Syntax Error View Post
    Basically crap in a drain hole near the pollen filter. If your not sure where it is a quick search will/should revel all
    Jun 2006
    Manchester, England
    Thanks for your help.
    I've found it I think: it looks like a vacuum cleaner crevice tool.
    It was full of leaves, gunge & water, which I have now cleared.
    I am now looking forward to some rain (for the 1st time in a month) to see if it has solved the problem.
  1. water in passenger footwell
    By brynsueg in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2013, 21:25
  2. water in passenger footwell
    By les287 in forum Bodywork & Interior
    Last Post: 10th October 2012, 21:23
  3. water in passenger footwell (help)
    By scottwales in forum General Motoring Chat
    Last Post: 5th July 2012, 07:26
  4. Could water in the passenger footwell be the cause of all my problems??
    By orangepeeleo in forum Vectra C / Signum Troubleshooting
    Last Post: 4th April 2010, 00:04
  5. Water in (rear) passenger footwell
    By shoeless79 in forum Bodywork & Interior
    Last Post: 19th March 2010, 00:57
