Thread: jerks back when changing gear
    Mar 2007
    northwest
    Default jerks back when changing gear
    just bought a vectra exclusiv 1.8 06 and i love it but the only thing what's doing my head in . when i set of in first gear then when i change to the second gear it jerks back and some time in third gear to so i took it back to the car dealer and he said its becous its a v something engine
    is it me or is it the car
    Regular Member MattW's Avatar
    Sheffield
    Quote Originally Posted by chalky333 View Post
    VVT?
    Mar 2007
    northwest
    so vvt engine don't change gears smoothly
    asdasd
    VVT are toyotas? arent they..
    mate you need a new car...joking..i dont know Hope someone else can help you mate..(i duno why i posted, i didnt help in anyway)
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Sounds like an engine or gearbox mounting thats shot!
    Sheffield
    Quote Originally Posted by vec3.2 View Post
    Vauxhall Vectra Hatchback (05-09) 1.8i VVT SRi 5d
    1.8i VVT SRi 5d 10.2 s 131 mph 138 bhp
    Regular Member barkzz's Avatar
    VVT's are a bit crap with the jerking between gears. Only when you have given it a bit of extended revs though.
    The old 1.8 block was far smoother
    Mar 2007
    northwest
    Quote Originally Posted by barkzz View Post
    yes your right that's whats happening
    Regular Member videodoctor's Avatar
    Blackpool
    My 1.8 vvti jerks when changing from 1st to 2nd.You need to press the accelerator down as you let the clutch up.The more revs you give it before the clutch fully bites the smoother it is.As a test try changing from 1st to 2nd without taking your foot off the gas.The engine will rev as you depress the clutch but if your quick enough,as you let the clutch back out the revs are high enough for it not to jerk.
    Unfortunately theres nothing you can do to erradicate it completely.
    I had a software upgrade applied to the engine a while back which kept the engine revs up for longer while you changed gear.It helped a bit but it still can do it.
    Jul 2009
    I get it on my 2.0 cdti but have been told by vx it's quite common. common or not I share the frustration.
  1. not changing gear !!!!
    By bert01909 in forum Engine & Drivetrain
    Last Post: 20th September 2011, 19:37
  2. Replies: 43
    Last Post: 8th June 2011, 21:03
  3. clunk under the car when changing gear
    By sharpo in forum Engine & Drivetrain
    Last Post: 24th July 2009, 15:41
  4. changing my gear knob...
    By PAULMAC77 in forum Styling
    Last Post: 8th March 2009, 12:52
  5. gear changing problems
    By abyh in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 12:23
opel corsa c jerks once when changing gears
jolt changing from 1st to 2nd vectra c
car jerks in 2nd gear opel corsa lite
why does my zafira b diesel jerk in 2nd gear
corsa c jolting when changing to second
corsa lite jerk between gears
insignia jerking when driving
zafira 08 jerks from 1st to 2nd gear in second gear
corsa d jolting when changing gear
violent jerk when driving in 1st and 2nd gear vauxhall zafira b
zafira 2nd gear jerk
my opel corsa jerks when driving in 2nd gear
Opelcorsa tht jurk when you change gears
opel corsa b lite jerk when driving
auto vectra jerking at gear change on warm up
my opel corsa jerk when in second gear
vectra c 1st 2nd gear jolt
