Results 1 to 10 of 15
Thread: bigger intercooler on a 1.9cdti 120bhp
    Regular Member dean_walsh2001's Avatar
    swansea
    Default bigger intercooler on a 1.9cdti 120bhp
    i was wondering has anyone on here or know of someone that has one on thier car. and does it make a differance to the performance and if there will be any props in the future
    member of the smoke patrol 230bhp+
    save the money and spend it on a remap
    swansea
    Quote Originally Posted by chrisgettings View Post
    hi chris i have already got a remap lol
    Regular Member Readster's Avatar
    Plymouth
    The theory is good but, you'll need other mods to make the most of it. big valve head,high lift cam, free flow exhaust etc.
    the usual tuning bits and pieces.
    swansea
    Quote Originally Posted by Readster View Post
    well i have got a remap vxr back boxes with centre pipe removed and a k&n panel filter
    Plymouth
    Got rid of the cat too ?
    Cold air is denser so gives more power but, as with superchargers there is a limit to the amount of air/fuel the engine can process.
    The standard intercooler should do the job, A thorough clean may be an idea first so, its as efficient as possible. See if that makes a difference...
    Try a K&N air filtre too.
    Be interesting to see the results.
    Leicester
    After market intercoolers are good, but you will not see any significant increase with the mods you already have.
    You could look at this another way, your 120 runs the same intercooler as the 150. This intercooler is perfectly OK with 150 cars running a re-map so it will be perfectly efficient in your car.
    If I remember correctly the Vectra VXR runs the same intercooler.
    as maverick has said the vxr is the same intercooler so is able to handle anything you put on your car
    i think you need to find out what your car pushes out first on a rolling road to see if the map is running right on the car
    Regular Member veccyjim's Avatar
    Mid Wales
    regal autosport do a upgraded intercooler for £750 fitted....and with their ipf remap a 120 or 150 16v cdti engine should put out 210-215bhp easily
    Winteringham
    from memory the regal intercooler is for Astra CDTi's the vectra will not see any inprovment in changing the intercooler
  1. Blank off the EGR on a 1.9cdti (120bhp)
    By Vectra-c-SRI in forum Diesel Engine related
    Last Post: 8th September 2011, 09:04
  2. intercooler is it worth fitting bigger one?
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2010, 20:20
  3. DPF and EGR 1.9CDTI 120BHP
    By robintwall in forum Engine & Drivetrain
    Last Post: 13th June 2009, 16:32
  4. Bigger Turbo - 1.9CDTI (150)
    By Seery_SRI in forum Diesel Engine related
    Last Post: 16th May 2009, 18:52
vectra c sri 1.9cdti 120bhp 8v bigger turbo
vectra 1.9 cdti intercooler upgrade
06 vectra 1.9 cdti 8v bigger turbo
vectra c cdti bigger intercooler
show vectra c 1.9 cdti intercooler
does increasing exhaust size give mor bhp
do vectra 120 have intercoolers
tuning a 1.9cdti 120 bigger turbo
intercooler vectra c big
vectra c 1.9 120 big turbo
