Results 1 to 10 of 16
Thread: please help.......2.2 direct.
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default please help.......2.2 direct.
    my new car - 2.2 direct elite.
    as soon as you turn the climate control off - it mists up really bad (all around).
    turn the fan up, fan off, temp low, temp high doesn't cure it.
    can anyone help me pls?
    Something as simple as Airflow set to ‘re-circulate’ worth a look hth ………..
    Suffolk
    the recirc light is off though
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Damp pollen filter?
    Suffolk
    Quote Originally Posted by BigP View Post
    Damp pollen filter?
    I was thinking a blocked pollen filter.....?
    Suffolk
    but as soon as you turn climate on - it goes.
    norn iron
    re-circ flap stuck
    Apr 2006
    If its raining the car is more likely to mist up, putting the A/C on dries the air and stops the misting. A damp or blocked pollen filter will make the problem worse.
    If you haven't changed it for a while its probably worth doing. Dealer service scheduling only changes them once every two years AFAIK, really needs to be done at least annually.
    While your changing it, make sure the drain plug is clear. HTH
    Suffolk
    where is the drain plug pls
    Surrey
    Quote Originally Posted by Judas View Post
    Under pollen filter.
  1. I think my 2.2 direct has too much oil in it....
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 15:18
  2. vectra 2.2 direct/non direct
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2009, 00:05
  3. 2.2 Direct mpg normally this bad?
    By Marc C in forum Engine & Drivetrain
    Last Post: 9th August 2008, 12:46
  4. 2.2 Direct 16v
    By cdms811 in forum Petrol Engine related
    Last Post: 12th December 2007, 00:55
  5. 2.2 Direct
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 20:50
