Thread: Strut top mountings
    Regular Member sharpo's Avatar
    Jun 2009
    York
    Default Strut top mountings
    Is there a way to lubricate the strut top mounts?
    I think this is where the orrible screeching noise is coming from and sometimes the springs can be heard pinging round as I go from lock to lock, maybe thats why they break alot on the Vec's.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have you got plastic sleeves on the bottom of your springs? Alot of vec/signums suffered with this and you can get the sleeves from you vx dealers. They stop the pinging noise
    Jun 2009
    York
    It's been lowered, not sure if it has the plastic sleeves on, i'll have a look.
    haworth
    I`ve put new springs on mine today and while in bits i gently took the top mounting bearing apart, just ease the bearing roller apart with a small scewdriver and put new grease in the roller and the ball carrier then clip back together, it is simple to do honest buddy, that is of course once the suspension leg and spring are off the motor.
    Jun 2009
    York
    Ok Thanks, i'll get my garage owning friend to have a look soon.
    Regular Member garvey's Avatar
    Co Durham
    they are about £15 each from stealers. cheap enough to change I had mine done twice now.
    Jun 2009
    York
    Thanks, probably worth it to stop the orrible noise.
  1. strut top
    By cj1175 in forum Suspension, Wheels & Brakes
    Last Post: 30th December 2011, 14:34
  2. Strut top nut
    By kalim in forum Suspension, Wheels & Brakes
    Last Post: 31st January 2010, 18:28
  3. Strut top question ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2010, 10:22
  4. Strut top
    By harny86 in forum Suspension, Wheels & Brakes
    Last Post: 29th December 2009, 19:02
  5. Strut Brace?
    By wotsthestory in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2009, 17:40
