Thread: boost gauges.
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Default boost gauges.
    i have just fitted a boost gauge to my 2.0DTI.
    the problem im having is that when i open the throttle the boost pressure rises to 20psi but as the revs increase the boost pressure lowers to around a steady 13-15psi.
    does anyone have anything similar happening and is it normal??
    cheers, mick.
    Regular Member ssmotoboyz's Avatar
    wednesbury
    completely normal mate the turbo will be allowed to boost higher initialy then will be pegged back to hold boost slightly lower
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    thats ok then, i thort there might have been a leak.
    thanks, mick.
    Regular Member bradley's Avatar
    Hartlepool
    Quote Originally Posted by mick 1986 View Post
    cheers, mick.
    hello how did you install the gauge m8. which pipe did you tap into to get a boost reading ?
    thanks
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    the large boost pipe that is at the front of the engine bay, at the top.
    it goes into the top inlet just above the EGR if that makes sense. let me know if you have any trouble. i will try and find a picture.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    http://i416.photobucket.com/albums/p...k/DSCF0186.jpg
    if this link works, its the pipe at the bottom right hand corner, large diameter black pipe.
    just to let you know though, i have taken my boost gauge off now as it kept going into limp mode due to leaks around the boost gauge tap off.
    Jun 2009
    Norwich
    i took my heat cover off of my turbo when i had the 2.0 dti, seemed to help, someone will say otherwise if its not...
  1. Turbo boost gauges.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2010, 22:46
  2. gauges???
    By damadom in forum Petrol Engine related
    Last Post: 8th September 2009, 17:30
  3. Additional gauges
    By greg_t in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 18:51
  4. pods + gauges HELP
    By V6rit in forum Styling
    Last Post: 5th April 2008, 15:42
  5. GTS Plasma gauges
    By Raffe in forum Styling
    Last Post: 5th October 2007, 12:43
