Results 1 to 10 of 17
Thread: Quick HELP! - Its All Gone BLANK
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    Default Quick HELP! - Its All Gone BLANK
    Hi all,
    Can anyone offer some quick help? Here's the problem.
    Currently 540miles from home and I've encountered a problem. Car has been fine all day with no probs then I make a quick stop at the shop, turn engine off and return literaly 2min later. Get back in car turn engine on and suddenly! I've got no temp gauge, no rev counter, no speedo, no fuel gauge, no oddometer readings etc.. Backlights to dash are on okay with lights and no engine management light on. Car started fine as it usually does and still drove like it usually does. I pulled in along the road and tuned engine off again. Turned key on and this time I notice there is a beep and the sole light I get is the amber engine light (bottom right of clocks), car will go on to starting fine and driving fine.
    Done a quick check of fuses but all seemed okay, could do with knowing which one if any are cause of problem tho. As I'm away from home I,ve got no manuals only my USB Mobile Broadband, hence I'm on here looking for a quick fix? Don't fancy the 540miles without normal dash, speedo etc.
    Bri.
    Mar 2007
    North East
    Tried the remove the battery for a bit trick ?
    My vectra did this once and the battery trick sorted it.
    Fareham
    Will give it a try, let you know in a few min.
    Bri.
    Fareham
    Yip that done the trick.
    I have already been looking at the fuses etc for nearly 2 hours before I came on here. So thankyou very much, much appreciated.
    NEXT PROBLEM!!
    Now I've disconnected the battery and connected again the radio just says 'SAFE' how do I put in the code etc? Normaly I would look up the manual but i aint got it with me.
    It's the VDO 2005.
    Bri.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    While the battery is disconnected unplug the ABS plug and make sure its clean. Mine dd this and a squirt of wd sorted it. Its ether a CIM problem, a fuse or dirty/wet ABS plug, all are quite common on early pre facelifts. HTH
    ABS unit is the thing with all the pipes coming out of it. The plug is the huge thing on top.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    turn the ignition on and make sure the stereo is off,then press and hold
    the as button then with another finger press the on/off button on the
    stereo while you have the as button pressed,then wait for the bleeps then
    release as button and enter your code by using the numbers on the stereo
    noting no1 is for your first number then so on,after entering ya code then
    press and hold the as button till it comes on.
    Mar 2007
    North East
    CDR 2005:
    Code Entry as Follows:
    Turn Off Stereo
    Switch On Ignition (No Need To Start Engine)
    Press & Hold Preset " AS " and
    Switch Radio On - Display Shows
    " SAFE " And Then Shows " 10 - - - - "
    Press preset " 1 " repeatedly for 1st Digit
    Press preset " 2 " repeatedly for 2nd Digit
    Press preset " 3 " repeatedly for 3rd Digit
    Press preset " 4 " repeatedly for 4th Digit
    If the correct code number is now shown
    Press & Hold Preset " AS " Until the Unit Beeps
    Fareham
    Hey guys, thank you ever so much.
    Believe me even I couldn't put up with my singing all the way down the road so your life savers.
    Going to get on the road now, eta 9hrs!!
    Catch you all later..., thanks again.
    Bri.
    Regular Member gibbon7000's Avatar
    lincs
    Quote Originally Posted by brifen View Post
    Bri.
    Glad your sorted, safe driving.
    Mar 2007
    North East
    Safe trip.
  1. Help! Where do I blank egr??
    By jones5n in forum Diesel Engine related
    Last Post: 16th May 2016, 06:56
  2. 2.2 dti egr blank
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 2nd March 2012, 00:50
  3. Where can I get an EGR blank for a 2.2 Vec C?
    By Partyvan in forum Petrol Engine related
    Last Post: 5th January 2011, 21:52
  4. blank egr off ?
    By peadar in forum Diesel Engine related
    Last Post: 27th October 2008, 23:01
  5. Map gone blank
    By Paul_O in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2007, 15:42
