Thread: Auxilliary belt tensioner......2.2 DTI
    Apr 2009
    liverpool
    Default Auxilliary belt tensioner......2.2 DTI
    Heard a bang on start-up coupla nites ago and found that the aux. belt had come off. After having it towed to a garage the damper strut thingie was replaced, circa 120 quid for the part, and a new belt.
    It's fine now apart from a very noisy idle. Sounds like it's a bearing or a drumming sound, but it disapears off idle speed.
    I'm wondering if they failed to bleed the strut before fitting, would that cause this noise? Or maybe just something fouling.....
    Before I let them have it back, any ideas please?
    I had the usual hole in intercooler hose fault a week or so ago, and diagnosed and fixed it myself thanks to all the great info on here. Thank You all.
    Shame on Vauxhall for refusing to sell just the offending part, you have to buy the whole assembly, 85 quid
    Regular Member toon sri's Avatar
    newcastle
    i have a 2.2 dti m8 with the same noise i think on what you have said I've had the belt tensioner crankshaft pulley done and its never sounded the same since its like a loud vibration noise just on idle not got a clue what it can be let me know how you get on m8 if that's ok cheers peter
    Apr 2009
    liverpool
    That's exactly what it sounds like. Lets hope someone here has something on it......
    Apr 2009
    liverpool
    After a proper chat with the garage, turns out the part replaced was the damper pulley after all.....the part which so many report failing.
    But that noise is still the same. It sounds just as you describe too. It's definitely only came on from when the pulley and new belt was fitted, all was quiet when it was running with the broken pulley........
    Anyone?
  1. fan belt tensioner
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 15th December 2012, 11:50
  2. v belt tensioner
    By micks edition 100 in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2010, 00:10
  3. Aux belt tensioner
    By jamesr in forum Engine & Drivetrain
    Last Post: 15th December 2008, 20:56
  4. Urgent Help!! Fan/auxilliary belt fitment
    By buggy_666 in forum Engine & Drivetrain
    Last Post: 28th September 2008, 16:05
  5. Auxilliary drive belt change 2.2 Direct
    By keith barbarez in forum Engine & Drivetrain
    Last Post: 7th May 2008, 00:49
vectra c 2.2 direct aux belt tensioner noise
