Thread: Vectra C Doors
    Jul 2009
    Waterford
    Default Vectra C Doors
    Hi Everyone
    I am a newb to the forums, but have been checking the site out for a while for different gems of wisdom.
    I recently damaged the front passenger side door of my 2003 vectra gts.
    I have contacted a number of breaker yards for a replacment door. They all have something to offer.
    My question is are the front doors on the vectra's different sizes i.e. would a vectra life or dti door fit my 2003 gts.
    Any help and/or suggestions would be much appreciated.
    Regular Member sri andy's Avatar
    Apr 2009
    Lancs/Manchester
    Hi, all the front doors are the same on the vectra c,the rears can differ like on the estate because of the roof line and i think the saloon rear doors may be different to the hatchback.They are a doddle to do so dont be scarred of having a go...hope this helps
    Jul 2009
    Waterford
    Smile
    Hi Andy
    Thanks for getting back to me. I was worried that the door would arrive and wouldn't fit.
    Shop was charging me €1650 to fit and paint a new door, I can get this door for €100 euro..
    The only difference I could see, from a pic, is that my current door has silver trim on the window but the other door does not. Do you know if this can be transferred ?
    Regular Member poves's Avatar
    lancashire
    Yes the trim can be transferred , it just slides upwards ( gently ).
    The door itself is really easy to swap over , just mark all the hinge and brackets with marker pen , so you get a good alignment.
    If your swapping everything from the old door to the new one , just take your time , everything is on bolts apart from the window motor regulator , this is held in with rivets.
    Apart from that , it should be plain sailing .
    Jul 2009
    Waterford
    Cheers Poves, I will order the door now and give it a go..
    Thanks for all the help
    Jul 2009
    Waterford
    Hi all
    I got my door and had it swapped over in about 40 minutes with a bit of help from a friend. It is very straight forward and the fit is perfect.
    Thanks Sri Andy and proves for your help.
    Jul 2009
    Waterford
    HI
    Anyone that is attempting to swap your door don't make the same silly mistake I did. When I swapped the door I didn'nt swap the base unit box i.e. the rectangle box on the inside of the door panel. This led to a deadlock on my door, not nice...
    I managed to swap the unit, with much difficulty as the door was locked. Beware....
    Feb 2011
    London
    Quote Originally Posted by Dazbaz View Post
    HI
    damn, wish i had read this earlier! trolling the forum for a solution to unlock my passenger door now!
    Feb 2011
    London
    sorted it. just removed the passenger seat, the half of the door card and swapped the control units over!
  1. Next doors vec dti
    Last Post: 4th October 2012, 06:39
  2. Looking for some 12v in the doors
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2012, 22:17
  3. Are Vectra Saloon and Signum Rear Doors Interchangable?
    By AdeV6 in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2012, 20:59
  4. Taxi Doors / Autolocking Doors
    Last Post: 17th April 2012, 19:05
  5. Vectra C Doors water retention
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2007, 18:22
