Thread: tyre pressures on 225/55 r16 vec 19cdti?
    liverpool
    confused tyre pressures on 225/55 r16 vec 19cdti?
    does anyone have this size tyre fitted? know their not factory fitted issue but mine have them on 4 corners and cant find out correct pressures,any ideas?
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by conny View Post
    Yep, they are not a VX recommended tyre size, but I would imagine that the tyre pressures would be the same as for 215/55/16 shown in the table below for Z19DTH engine (Click on attachment):-
    Attachment 13412
    The slightly larger width is minimal and the side profile is the same as the standard 215 and 205 width tyres.
    Hope this helps
    Regular Member Boy Lard's Avatar
    Derby
    Quote Originally Posted by john_k_sri View Post
    Hope this helps
    Not strictly true. The side profile is 55% of the width.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    rule of thumb for pressure is rim size 16'' x 2 +2lb....
    i would be running 34lb in them if it were my car...
    HTH
    Midlands Mod Shop - NFFC.
    liverpool
    Quote Originally Posted by ditchp View Post
    HTH
    cheers lads,thought it would be around 35psi.thanks for taking the time out
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Mileage : 72K
    Quote Originally Posted by Boy Lard View Post
    Yes you're right. The net result of using the wider tyre with the same side profile is to increase the sidewall height by 5.5mm. I assume that would not be a problem, although wider tyres would normally have a decrease in sidewall height.
    For example:
    Replacing 215/50/17 (Vectra 'C' standard 17" tyre) with 225/45/17 (VX-recommended alternative tyre size for Vectra 'C' with 17" wheels) reduces the sidewall height by 5mm from 112.5mm to 107.5mm
  1. Tyre Pressures
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2010, 20:37
  2. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  3. Tyre Pressures
    By Johnny89 in forum Suspension, Wheels & Brakes
    Last Post: 16th April 2008, 13:47
  4. Tyre pressures...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2007, 20:25
  5. Tyre Pressures (again)
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2007, 13:46
tyre pressure for 225 55 r16
tyre pressure 21555r16 for vectra
vectra 225 55r16
vectra tyre pressure 21555 r16
vectra c 22555 r16
22555 r16 tyre pressure
225.55.r16 tyre pressure
