Results 1 to 10 of 15
Thread: Fitting Dashmount - Help!!
    Regular Member Happy Dave's Avatar
    Nr Blackpool
    Default Fitting Dashmount - Help!!
    Hi
    trying to fit a dashmount around the heater control area, I've popped the heater control out with no problems (using a gap opener on the left edge) but I cannot get the storage tray to pop out the same way, and advice on where i should be trying to get it out from, is it the left, the top, bottom or right???
    I admit to being a bit light handed with it but the heaters popped out with no problems
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    My dash mount only requires the heater controls out. To get the coin tray out, put your fingers right to the bottom of it and try and lift it from the back first, this should unclip it and it will slide out HTH.
    Full Member paul.sessions's Avatar
    leighton buzzard
    there are little holders along the top and along the bottom not so much clips, give a good tug and it should come out took mine out today no probs might be easier to take the ashtray out and the plastic lighter surround trim. that just requires pulling off aswell two clips...
    Nr Blackpool
    cheers, will give it a go tomorrow and see what happens
    Nr Blackpool
    well as an update, thanks to the help here I managed to get the storage tray out as well (pushed it over the cig lighter and ashtray) popped the heater controls out but even having a print out of the instructions with me cannot get the dashmount to locate. Haven't a clue what I am doing wrong, I've fitted loads of the Brodit ones to various cars without any issues, so I am assuming this one was for pre facelifts and something small has changed on the facelifts or I'm just not confident enough to use enough force.
    So if anyone wants a dashmount for the heater control area its all your for a small contribution towards P&P (about £3) - I'm off to buy a Brodit one!
    Dave
    Vehicle : SRi
    Mileage : 137000
    Originally I bought a metal one which didn't fit, I ended up getting a Brodit and it was fitted in 5 mins.
    Nr Blackpool
    yeah this is the metal dashmount one I have. Is the Brodit one a good fit? I'm mounting a Brodit ipod holder on it, just thinking about passengers knees giving it a knock. I've already got the drivers window vent in use with a brodit mount and the centre console one looks like it would block the nav screen view so thats the only place I have left to fit one
    Vehicle : SRi
    Mileage : 137000
    Mine holds a Sony holder so there quite wide it it sits fine for me.
    There's a pic HERE from another post.
    Jul 2009
    london
    Glad you managed to get the heater console out. I was amazed how easy it came out and even more amazed that there was enough space behind the panel to take the handsfree control unit. I ended up fitting a brodit console jobbie. Really simple to fit once you figure out what needs to go where and how to wiggle it into place.
    I didn't peel the backing off the sticky stuff because I'm not sure about it yet. With the phone holder mounted, it seems to get in the way of the knob to direct the airflow. Does the dashmount cause the same problem ?
    Probably a bit early to say it really irritates me, but if the dashmount isn't so close to the control knob, it might be the next option
    Nr Blackpool
    thanks for the photo rushy, that looks about right - I'm going to buy the Brodit, unless ....
    Kabooboo wantsa to swap his Brodit for my Dashmount, its this one http://www.dashmount.co.uk/July02/71209.htm
    edit: but be warned I cant get it to fit and I don't think Rushy could either! Anyway let me know or tomorrow I'll just order the Brodit one
  1. EBAY: Vectra B Dashmount
    By ccsnet in forum General items for sale
    Last Post: 21st April 2008, 12:53
  2. Dashmount Bracket - Vectra/Signum Pre-Facelift
    By sonic in forum Parts for sale
    Last Post: 20th March 2008, 08:53
  3. Dashmount Bracket- Vent Mount for Vectra / Signum
    By bennyk in forum Parts for sale
    Last Post: 17th March 2008, 11:16
