Thread: Alarm
    Regular Member yadziyad's Avatar
    London
    Default Alarm
    Hi i read a thread on here a few weeks back about disconnecting the alarm speaker in the boot which would make the horn takeover. well i tried it and the speaker just kept going of even when it was not in the car after i disconnected it and the horn didnt take over. what am i doing wrong.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Sorry if this is a silly question, but you did remove the wire from the speaker? If so i cant see how it could possibly go off
    London
    yep i removed the wire and had the speaker in my hand it kept going off so i took it into the garage and left it there while i was checking to see if the horn takes over.
    Mar 2007
    North East
    It is a factory fit alarm ??
    Decent aftermarket alarms have self powered sounders.
    11 Post(s)
    Quote Originally Posted by rockh View Post
    The factory fit one also has a battery back up - or at least it used to.
    If the factory fit one has a battery back up then to stop it from going off when disconnecting the main car battery, first you have to turn on/off the ignition and then disconnect the battery within 15 seconds. Once you've done this then try disconnecting the power sounder.
    Mar 2007
    North East
    Some more info to file away. Must admit when I took mine out of the old vectra so I could get better access it didn't do anything (just unlocked the car and started to pull things apart ).
    London
    ok but why didn the horn take over
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by yadziyad View Post
    Horn doesn't take over on my 02 GSi either - some do, some don't.
  1. Car alarm keeps going off
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2015, 18:37
  2. Alarm keeps going off?!
    By Ben Chiles in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2012, 22:26
  3. Alarm led?
    By Vectra Karl in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2012, 22:43
  4. alarm keeps going off
    By the fisherman in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2011, 01:22
  5. how do i get to my alarm??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2010, 19:51
