Thread: Fault Code reader or investigation charge?
    Regular Member johnmac's Avatar
    Apr 2006
    Inverclyde
    Default Fault Code reader or investigation charge?
    Cannot use the 'trick' of reading my fault code as it's a direct.Dealer wants £45 too investigate the issue.If it turns out to be the high pressure fuel pump, I may have a bit of comeback as its on the Dealers system as only being replaced last year.
    Fault code reader of Ebay is around £30, but that may simply point to the HPFP and Id still have to go into Vauxhall to get it checked if I wanted to pursue any action.Are these readers any good?
    John
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    I dont think you can really knock them for the price. I hope to be buying one in the future, use it once & you are quids in! (not that I want to use it...) of course the kit the dealer uses will be far superior, but £45 for 5 mins work?
    Apr 2006
    Inverclyde
    Regular Member swirl80's Avatar
    Jun 2009
    sorry to hijack but i'm interested in one of these as well. Any recommendations?
    what about this:http://cgi.ebay.co.uk/ws/eBayISAPI.d...MakeTrack=true
    Apr 2008
    Staffordshire
    have a quick read though this thread, its going back a year so things may have changed..
    http://www.vectra-c.com/forum/showthread.php?t=56147
    a more recent thread...
    http://www.vectra-c.com/forum/showth...ht=code+reader
    Apr 2006
    Inverclyde
    Are the U480 OBD II CAN BUS readers compatible with the 2004 2.2 Direct Vectra? Not sure if my car is 1/2 or full CAN BUS. Also where is the connection hidden? Are the readers better/more efficient than the similar priced laptop based readers? I do not want to fiddle about with any programming, I simply want to get a code to look at my engine issues. Dealer wants £45 for a basic diagnoses, but the price could increase if it requires more investigation wtf? and then I still need to resolve the issue.Potentially looking at the HP fuel pump (again)
    May 2008
    Tyneside
    I use the U581 reader on my 1.8l petrol with no problem, says its OK with all petrol cars from 2001. One on ebay here:http://cgi.ebay.co.uk/Car-Code-Reade...3A1%7C294%3A50. The diagnostic socket is under the front ashtray, just lifts out.
    Apr 2008
    Staffordshire
    Quote Originally Posted by swirl80 View Post
    even though it mentions op-com i think there is better out there, just had a quick look on ebay & the seller who sold the ones i was interested in is no longer a registered user *think* the one I wanted was similiar to the U581
  1. Fault code reader??
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2011, 15:36
  2. fault code reader
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 19th July 2010, 21:05
  3. Which Fault Code Reader?
    By peakfreak in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2010, 01:20
  4. fault code reader in n/e
    By no1golfer in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2009, 20:27
  5. Fault Code Reader
    By fattony in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2008, 22:40
