Was just wondering if any1 has fitted a traction control button to there 54 reg vectra or if i can fit it an will it work
thanks
thanks
I asked this, and was told that the Diesel's dont have switchable TC, the button may simply work as another lit up switch.
Do you kno how i get the blank off so i can see the plug??? do i just stick a screw driver behind it an just go for it or is there a proper method of doin it???
Ok will do thanks for the advice
It may do, it may not
If it has TC then it may be able to be switchable too.
Blue tack. Stick it on and pull the blank out. Trying to use a screwdriver will probably damage the sourround. If the plug is there - not all have them - then its still only about 50/50 that it may work.
