Results 1 to 3 of 3
Thread: Need help with clutch rattle that dissapears when clutch depressed
    Hertfordshire
    Default Need help with clutch rattle that dissapears when clutch depressed
    I have owned my 52 plate 3.2 GSi for two months now and I have noticed a tapping sound coming from the gearbox/clutch area.
    The noise is constant. It doesn't matter whether the engine is hot or cold or whether the vehicle is driving or is idling the noise is always there. The only time it goes is when I press the clutch pedal.
    Took the car to my local Vauxhall dealers and they said it was the release bearing in the slave cylinder but surely this noise would only be there when the clutch was pressed, not the other way around.
    I have had some people suggest the dual mass flywheel while others say it is the clutch so now I am totally confused.
    Please can someone help!!!
    Jul 2009
    reading
    iv got a 1.9cdti 120 05 plate that does the same thing
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Sounds like a release bearing to me.
    Years ago when I did my own clutch changes I had similar symptons a few months afer I'd done a change and left the bearing alone !
    Box off again.....
  1. clutch rattle (not dmf)
    Last Post: 9th December 2012, 15:41
  2. clutch noise when pedal depressed
    Last Post: 22nd October 2012, 23:19
  3. Grinding noise when clutch depressed
    By y2joeyb in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2012, 11:27
  4. DMF query, rumble at idle and if clutch depressed
    Last Post: 19th November 2011, 10:27
  5. clutch rattle
    By Xpolicevectra in forum Engine & Drivetrain
    Last Post: 21st December 2009, 20:48
vectra c rattle when clutch depressed
vectra c 1.8 rattle when clutch depressed
