Thread: Automatic Windows
    Dec 2005
    Renfrew, Scotland
    Default Automatic Windows
    Guys,
    Just noticed today that my drivers side automatic open/shut is not working.
    Works fine for the passangers from the passangers door and also drivers door.
    It was working up until a couple of days ago but hasnt cleared.
    Ive looked through the manual and tried the tip it suggests on page 128.
    Anyone else got any ideas?
    [Ex]Admin Duncan's Avatar
    Not sure what the tip on Page 128 is (as there are different versions of the manual). But normally if a window has lost it's auto setting, you wind down the window, then wind it up keeping the up button pressed for a few seconds after it has closed. You'll hear a little click. That should normally be it.
    Don't know if that's what you've tried already?
    Regular Member david173's Avatar
    Dec 2005
    Dumbarton, Scotland
    Mines done the same thing yesterday, lasted about half an hour and fixed itself though.
    Dec 2005
    Renfrew, Scotland
    All sorted now - big thanks.
    If only the manual was as descriptive....
    CYPRUS
    Yesterday i had a problem with the co- drivers window. I opened it from drivers door and when i tried to wind it up it simply refused. It refused from the codrivers door as well. After a while and a lot of tries it closed. I did not try to open it since.
    Any known remedies to fix this problem?
    try the connector that takes the wiring into the door from the car.. that may be the problem.. or you may have a broken wire...
    This one will take some digging by an auto electrician to find..
    CYPRUS
    thanx a lot
  1. Automatic help
    By Kev_1664 in forum Engine & Drivetrain
    Last Post: 13th October 2010, 08:04
  2. windows automatic not working
    By iasha in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2009, 22:04
  3. Automatic
    By Robert Greenway in forum Engine & Drivetrain
    Last Post: 28th July 2009, 13:06
  4. Automatic Box
    By WeDesign in forum Engine & Drivetrain
    Last Post: 9th March 2009, 16:07
  5. Windows Wipers and Windows Washers
    By kevrod79 in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2009, 09:58
