Thread: wet Passenger side Footwell
    Stockton on Tees
    Default wet Passenger side Footwell
    Whilst giving the inside of my Vec C a clean last night i came across a wet carpet in the passenger side foot well. Remembering previous posts on here i checked the Pollen filter which was damp. Just infront of the pollen filter there was a puddle of water. I pushed my fingers through a rubber sleeved hole and removed all the leaves and crud. The water soon disappeared.
    My question, 'is this all i need to do, or is there other things that could of caused this.' the carpet is wet but is there a drain in that area to remove any water if needs be.
    Steve
    You have done all the right things, no drain in the foot well but keep an eye on that drain near the pollen filter. I would change the filter if it has been water logged.
    I also cut off the top of a lid from a spray can to fit in the flexi drain just to keep it open. hth .........
    Stockton on Tees
    cheers. at least its hot here. hopefully be dried out by the time i finish work!!
    n.ireland
    just had the same thing happen to me this morning.the car had been sitting in the drive for a few days and it has been ****ing down,checked the drain hole in the bulk head and it was full of crap.have pulled back the carpet and lifted up the sound proof,now just need a few warm days to get it all dried out.
    Quote Originally Posted by marky1 View Post
    I would check the Pollen Filter Mr Marky & replace if at all suspect this I think is worth a mention if you haven’t done it recently guys check that drain hole. Could save you an expensive repair never mind the inconvenience.......
    n.ireland
    would it affect the heater blower motor as it only works on number 4 now
    Try a seach or this thread Link should help as there are some fixes listed ......
    n.ireland
    thanks,just after reading that thread so thats my next mission.
    cheers
    cheers
    Catch you in a day or so plenty to read ...........
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Default wet carpet
    Hi got the same problem , cleaned the bung .........rained like hell today and carpet feels wet again...........no coolant loss, any one any ideas? any help would be appreciated.
    Andy
  1. Water in Drivers side passenger (rear) footwell.
    By firemanshrek in forum Bodywork & Interior
    Last Post: 25th September 2012, 14:39
  2. woke up to a massive pudle of water in passenger side footwell
    By danny1992 in forum Bodywork & Interior
    Last Post: 27th February 2011, 15:12
  3. Wet passenger footwell
    By aaruck in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 11:13
  4. Passenger footwell wet in the Vec-B, HELP!
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 22:22
  5. wet passenger footwell
    By al21784 in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2007, 23:42
