Results 1 to 2 of 2
Thread: 2.2 Direct Sump Plug
    Regular Member johnmac's Avatar
    Apr 2006
    Inverclyde
    Default 2.2 Direct Sump Plug
    Probably an obvious one, but Ive never done the oil and filter before !!!
    Had a look under the car tonight to locate the sump plug.If it is where I think it is, it looks like a socket fitting and not a torx fitting. Is that right? If so, does anyone know the size of the socket requried.It looks around the 15mm size. The last time the oil would have been drained would have been at the dealers approx 1 year ago.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    13mm socket. very difficult to remove as it rounds off, get a new one first then be prepared to use a hammer and chisel.
    there has been a few threads recently on this very subject.
    http://www.vectra-c.com/forum/showthread.php?t=87057
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Sump Plug
    By Tam80 in forum Engine & Drivetrain
    Last Post: 13th February 2011, 18:55
  3. Sump plug
    By Daywalker in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2009, 19:48
  4. Sump plug?
    By vec04 in forum Engine & Drivetrain
    Last Post: 10th December 2008, 20:58
  5. getting the sump plug out ????
    By Nickzx6r in forum Engine & Drivetrain
    Last Post: 6th October 2007, 07:55
vauxhall vectra 2.2 where is sump plug
vectra c 2.2 direct sump plug size
vectra 2.2 oil sump plug
what size socket for vectra sump plug
vectra c oil sump plug size
vectra c 2.2 sump plug size
