Thread: 52 2.2 elite auto no drive
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    Default 52 2.2 elite auto no drive
    car has now lost all drive did go reasonably slowly just slightly noticable then whammy no go at all seems to select the gears just fine including in manual mode but engine revs lift with throttle but no go at all almost like clutch gone in a manual.
    scanner shows codes relating to speed sensors exact codes can be provided if required rac towed her home he seemed to recon it might be some kind of saftey lock out of gear if all correct sensor readings not present can anyone help i've not a clue about autos i couldnt even see a transmission dipstick to check the oil
    I don't know anything about Auto's but do hope you are able to sort the motor, good luck ..........
    Glasgow
    Check your coolant level how is that sitting?
    Apr 2008
    Wigan
    coolant leavel is about where it always is
    Glasgow
    It does'nt sound like the common autobox problem then. If you do a search there is plenty about that on here.
  1. 2.2 auto drive problems
    By jon1.9cdti in forum Vectra C / Signum Troubleshooting
    Last Post: 30th December 2012, 20:48
  2. 04 sigbum 2.2 auto, lost drive
    By Mopar Man in forum Engine & Drivetrain
    Last Post: 2nd February 2012, 11:06
  3. Af40 auto gearbox loss of drive.
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2010, 21:57
  4. 2.8t Elite test drive
    By paulwilco in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 23:09
  5. Auto Express get a drive in the Insignia
    By jonesy_ni in forum Insignia car chat
    Last Post: 15th August 2008, 07:02
