Thread: Disconnect battery?
    N
    Default Disconnect battery?
    Hi all,
    I need to remove my car radio (CDR 2005). Problem is that I don't have the code but have been told it should be behind the actual radio. So is it safe for me to just remove the radio, not actually unplugging it, without disconnecting the battery so i can verify the code is in fact there?
    Also IF the code is there, do I have the disconnect the battery before I unplug the radio, or can I just unplug it while battery is still connected?
    Stockton on Tees
    Just take it out. You'll be able to read the code with it plugged in.
    Regular Member madman's Avatar
    nottm
    i removed my radio and it unplugs immediatly. there was no lead with a plug on. you just push it into the space and the plug auto connects. without the code you wont be able to usae the set again
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Yea, if you pull it out it unplugs, it only takes 5mm and its unplugged. From what I remember the code is not on the stereo back. If you don't have the car pass (little card in car wallet) then just go to the dealer, a nice one might not charge you.
    N
    The radio is actually a reconditioned unit the previous owner told me and said that its code was written on the back of the stereo by whoever he bought it. Well I did this yesterday not knowing it would immediatly disconnect . Took it out and thankfully it was written there!! Phew!
    Now time to try the Aux mod
  1. Is it ok to disconnect EGR plug..?
    By Dippy-Vx-line Red in forum Diesel Engine related
    Last Post: 6th June 2012, 17:05
  2. CD30 battery disconnect
    By 19CDTi in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2012, 20:48
  3. Will I need to disconnect my battery
    By ballmonkey in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2007, 14:37
  4. Problem after battery disconnect
    By Penfold in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2007, 20:02
  5. disconnect battery after remap?
    By trucker in forum Tuning
    Last Post: 17th September 2006, 08:49
how to sisconect batery vectra c
