Thread: Air Box question
    Jun 2009
    Chelmsford
    Default Air Box question
    Have just done the air box mod on my 1.9cdti sri, and when cleaning out the bottom of the airbox, noticed a small hole size of a 10p piece in the bottom near to the air intlet pipe, on looking outside the box noticed a small rubber pipe that looked like it should be in this hole! Anyone know what its for and is it important that i put it back! I have had the car for 5 weeks now before looking at this mod and i guess that this pipe has been out all this time, not noticed any problems with it out!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    dont know what it does.. but better put it in anyway.
    Full Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    I have a 2.2DTi so not identical airbox, but on mine there also is a rubber pipe connected to a hole in the bottom of the box. Ill guess as long as the hole in yours is at the bottom, it is drainage for water, and the rubber pipe is for leading the water outside the compartment. Pretty sure you should put it on
    Bent, my name is Bent
    Mods: I polished it in september...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Its a breather pipe, it doesn't cause any problems with it disconnected - so don't worry.
    I have had mine disconnected for months now and its been fine.
    Regular Member Pete B's Avatar
    Malvern
    Quote Originally Posted by fikse View Post
    Mine (1.9CDTi) is the same. It doesn't matter too much whether it's connected or not, as long as the hole is clear. All the pipe does is ensure any water that gets in the airbox drains away and runs out below rather than running onto and then down the inner wing. So although it works either way, it's obviously better if the pipe is connected.
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
what is the pipe conected to the bottom of the airbox vectra c
