Thread: Possible to extend functions on a Eberspächer?
    Regular Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    Default Possible to extend functions on a Eberspächer?
    In my 2.2DTi it is factory-mounted a Eberspächer heater. It works very simple; dependent on outside/engine temperature, it starts heating the water for the compartment, when you start the car. So far so good, this works perfect in my car, heating the compartment within few minutes, even during the really cold days.
    But, Old Nick always want more!
    It would be perfect to have this heater to heat the car before I start up in the morning. During wintertime this will be a huge raise in comfort!
    In the owners manual, I can see it is an option to have this heater started/stopped by a timer, built-in to the GID, and also have this remotecontrolled. According to this manual, I belive I have "everything" needed, apart from No7: "Stationärteil für Funkfernbedienung TP 44", a part with "JE - Bestell Nr. 22 1000 32 04 00" (partnumber at Eberspächer?), and Opel/VX partnumber 9 163 045. I'm not 100% sure what this part does, is it maybe only a remote receiver, or is it also controlling the timer thing?
    Any suggestions most welcome
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    actually think it can be coded in to the GID.... so you can set the timer there... the other parts you list is the remote..
    change the code index in the GID and it should be possible to program ahead..
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    'Cough' i feel a retro fit coming on. Could this heater be fitted to my 2.2dti easily?
    Engine : 2.2 Direct
    i actually think all DTI´s have them... (not sure)
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Anyone have a picture of the unit so i can have a look
    Apr 2009
    Bergen, Norway
    Give me a few minutes. I will take some pictures, and explain what answer Ill got from my dealer, and a Norwegian forum
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Engine : 2.2 Direct
    john -> theres also help here.. (use google translation if you cant read german) http://www.motor-talk.de/forum/stand...h-t467012.html
    Engine : 2.2 Direct
    found a guide for you http://www.ifz-berlin.de./db_select_instruction.php on the part nr. go all the way down to WS and WZ to find the correct model (dielsel, petrol with and without ECC)
    Apr 2009
    Bergen, Norway
    OK, here is a couple of pictures. Guess it's quite obvious where in the engine room it is placed; just below the diesel filter. It is a aluminium grey "can" with a yellow sticker (SJ letters) on it, with some fuel line into the top, and a tiny exhaust pipe (bronze coloured pipe) going to under the car.
    Here in scandinavia many diesel cars have some kind of extra heater, either fuel driven or electric, as standard. In other countries, like Germany, it will normally not be standard, I don't know about GB/UK.
    I asked my dealer, and got a very accurate answer. My variant of heater is the same they use in more advanced versions. Mine does not have a circulation pump for the cooling water, so it will only be able to heat when the engine is running. It heats the cooling water, the engine's waterpump will distribute the heat. It is nothing I can do with it, it works automaticly, and it will only work if a combination of outside temp and engine temp is low enough.
    SO, what I need, is a circulation pump and a few parts related to this, and then a Tech2-job. It was rather pricey, approx £1.200 with all, only the pump was approx £600! But, my dealer is the helpful kind, telling me that there are "other places" they sell this upgrade set for a smaller price. I found a Opel site here in Norway, selling the set for approx £450, included the receiver for remote controller. The remote controller should be easy to get on ebay or similar, since it is a standard thing with standard frequencys. It's pretty straight forward to mount it myself, and then I can get my dealer to Tech2 it. It needs some new software, so most probably I cannot do this with a OpCom.
    I dunno if I'm gonna do this, it is some money, and it already does the most important thing, getting the engine and compartment fast warm even on the cold winterday
    You can hear it a bit, but not much noise, it's a kind of "burning sound".
    Hope this helps others
  1. BC Functions
    By eeyore in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2011, 10:18
  2. Extra Functions
    By Ken072 in forum Electrical & ICE (including SatNav)
    Last Post: 11th July 2011, 22:37
  3. Advice on the best way to extend a sky cable
    By olid2002 in forum General Chat
    Last Post: 29th May 2009, 08:02
  4. Should i extend my warranty
    Last Post: 14th January 2009, 09:29
  5. Network Q warranty - managed to extend it again!
    By Duncan in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2007, 21:01
